Originally Posted by horn4life
It the screws are stripped and you have a cabinet behind iT I would likely add the extra wood support but I would probably drill out the hole and use stainless steel bolts, washers and lock nuts. Actually on the inside it would not matter if it was stainless. I would much prefer to climb up on something bolted in, rather than screwed in where the screws already stripped out once.
I would also be taking a real hard look at all the other screwed in ladder supports.
I am going to look at that this weekend while we're at an RV park but I'm leaning toward the strongback/through bolt fix, the pantry is in that corner so should not be a problem. But does anyone know what is actually in these walls? Is it rigid board insulation between studs?
