Old 02-05-2020, 04:55 PM   #1
Leaking roof 2003 cedar creek 36 rlts
I bought a 2003 Cedar creek 36 RLTS two weeks ago, the couple I bought it from kept under an enclosed shed for 10 years. It is now sitting in my drive and the exhaust vent in kitchen is dripping when it rains, I put new sealer around vent on roof, rained this morning and have drops from the vent any suggestions?
spagnolia1 is offline   Reply With Quote
Old 02-05-2020, 05:24 PM   #2
Cabinfever97's Avatar
Pics from the inside and outside would help in giving you some guidance.
Cabinfever97 is offline   Reply With Quote
Old 02-05-2020, 06:43 PM   #3
SeaDog's Avatar
Usually kitchen exhaust vent are located on the side wall maybe you sealed the frig vent.
Retired Navy
2016 Flagstaff 26 FKWS
Old 02-06-2020, 11:01 AM   #4
I added four pics if these help,
ID:	222923   Click image for larger version
ID:	222924   Click image for larger version
ID:	222925   Click image for larger version
Old 02-06-2020, 11:03 AM   #5
I have added 4 pics to thread
Old 02-06-2020, 03:52 PM   #6
It maybe coming in some where else running to the vent
kennyny is offline   Reply With Quote
Old 02-06-2020, 06:37 PM   #7
wayne272's Avatar
Is the plastic vent cracked somewhere? They become very brittle over time.
wayne272 is offline   Reply With Quote
Old 02-06-2020, 09:21 PM   #8
The whole roof looks like it could use some sealer. Also the vents are pretty weathered. Maybe start with replacing them and apply a sealer to the rest of the roof. Good luck.
shadows4 is offline   Reply With Quote
Old 02-07-2020, 08:03 AM   #9
Had SAME thing HAPPEN, caulk around all screws and bolts on inside of vents
Kayak is offline   Reply With Quote
Old 02-07-2020, 08:06 AM   #10
I mean between roof and cover outside
Old 02-07-2020, 09:13 AM   #11
Might not be a bad idea to clean the sealant around everything on the roof and check for any voids. You cant over seal anything on the roof. Doesn't look like that roof had much care over the years.
2019 Hemisphere 272RL
2015 Ford F250 6.2L
Hensley Hitch
Old 02-10-2020, 08:38 AM   #12
Thanks for all the reply's, I found a pin hole on the seam by the vent, sealed up until the rain lets up in a few days and will power wash and apply new coat of sealant to roof. Roof not leaking will hold until the weekend.
Old 02-10-2020, 08:46 AM   #13
Looks like the roof needs a good cleaning and treatment , may find more pin holes
MR.M is offline   Reply With Quote
Old 02-10-2020, 09:29 AM   #14
That roof looks in bad shape.
Did you clean or treat the area under what you smeared on there before applying?
What sealant did you use?
It may simply be you didn't get a good sealant bond to the dirty roof.
Days Camped: '17=30 '18=51 '19=58 '20=98
cedar creek, leak, roo, roof
