Old 04-29-2021, 08:25 AM   #1
PSA: check your roofs
Just brought the new trailer home and thought to check the roof for possible leak points. Sure enough I found several doosies; exposed staples and open bubbles at the seam caulking. Please check your factory fresh rigs to prevent water intrusion from day one. My mistake I did not check the roof at our initial walk through at the dealer. Easy enough to fix with some Dicor Self Leveling in the driveway.
ID:	253125   Click image for larger version
ID:	253126   Click image for larger version
Chuy12 is offline   Reply With Quote
Old 04-29-2021, 09:35 AM   #2
Always Learning
Agreed. My PDI tech was surprised I got on the roof and under the rig during our walk-through. And trust me, I hate getting up there.
I definitely found a few places that needed Dicor to be reapplied.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 04-29-2021, 10:05 AM   #3
Good point to check under the rig for leak points. What should I look for, being all black under there it may be harder to see issues.
2021 FR Salem Cruise Lite
Old 04-29-2021, 10:35 AM   #4
Always Learning
Find the lowest points (2 or 3 of them) and carefully drill a 1/4" hole. Later, look for wet spots under them.
Old 04-29-2021, 10:42 AM   #5
Wow! That's disappointing but a good catch.
I too got on the roof WITH the dealer during the PDI/Customer Orientation and had them correct anything I thought suspicious. They had already had it pretty good shape when we got up there. Just an antenna coax penetration point I had concerns with was all.
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 04-29-2021, 05:37 PM   #6
PDuB-IA2MI's Avatar
This made me go give my roof a once over, and I found this gaping hole!
Can I just cover this with self-leveling Dicor?Click image for larger version
TT: Wolf Pup 16BHS-Black Label
TV: 2020 Traverse V92 Tow Package
WDH: Equal-i-zer 600/6000
Brake Controller: Curt Echo
PDuB-IA2MI is offline   Reply With Quote
Old 04-29-2021, 07:00 PM   #7
rmac04401's Avatar
Where is that located on roof? Looks like you may have tagged something.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 04-29-2021, 07:07 PM   #8
High Country Duramax's Avatar
Iíve been fighting this last 2 years. This the the 4th screw coming up through roof!?
High Country Duramax is offline   Reply With Quote
Old 04-29-2021, 07:55 PM   #9
PDuB-IA2MI's Avatar
Front centerClick image for larger version
Old 04-29-2021, 08:08 PM   #10
Can I just cover this with self-leveling Dicor?Attachment 253171
WOW!
Good you caught that.
Yes self-leveling Dicor, if that meets the standards for your make of roof membrane.
You could also use Eternabond or Alpha-Bond type tape, depending on your roof membrane.
Old 04-29-2021, 08:56 PM   #11
rmac04401's Avatar
ID:	253200Click image for larger version
ID:	253201Click image for larger version
ID:	253202Click image for larger version
ID:	253203Click image for larger version
This is how I fixed my front cap/roof seam. Eternabond tape. Did this to my prior camper 1st thing. Due to Heath issues took me a couple of years to do on this one. Should be worry free now
2005 Honda VTX 1300
Old 04-30-2021, 11:29 AM   #12
That's terrible! It never should have left the factory like that! Quality Control is non existent with a lot of RV manufactures today ��
BudC is offline   Reply With Quote
Old 05-02-2021, 11:37 AM   #13
rmac04401's Avatar
1st two pics is what it looked like,3rd pic is in middle of me fixing. Last pics are finished.
2005 Honda VTX 1300
Old 05-03-2021, 07:39 AM   #14
Canoeing and camping fun
Quick question did you remove any of the front cap seal mess before applying the tape? Our front cap seal looks like they applied it then immediately went on the road at 80mph to get as many ripples and bumps as possible in it!
Jean D is offline   Reply With Quote
Old 05-03-2021, 11:27 AM   #15
rmac04401's Avatar
That was third pic. I removed all decor on fiberglass cap up to the retaining strip. Then applied over decor on strip, and roof membrane ending on just roof membrane. If any work would need to be done would cut at retaining strip peal back the decor under tape and peal back. That will only be if a new roof membrane is needed.
2005 Honda VTX 1300
Old 05-06-2021, 08:40 AM   #16
Oh wow, not good, thanks for the heads up I will be watching for this too...
Old 05-06-2021, 08:09 PM   #17
dmctlc's Avatar
How long has that hole been there? I'd be concern if rain has got into there that you might have a mold problem. Have you check the walls and frame to see if its been leaking all the way down. Covering it up until its been dried out or check could cause you bigger problems.
dmctlc is offline   Reply With Quote
Old 05-07-2021, 05:16 AM   #18
Attachment 253200Attachment 253201Attachment 253202Attachment 253203Attachment 253204
Here's a detailed step-by-step on how to Eternabond your roof edges. This will be my summer project. https://youtu.be/zUxnQ6C1BlY
jefrec27 is offline   Reply With Quote
Old 05-07-2021, 10:37 AM   #19
Eternabond The entire length.That's What I did. Actually I eternabonded the edges all The way around. All 4 sides as precaution
RobinDella is offline   Reply With Quote
Old 05-07-2021, 11:28 AM   #20
Roof
What brand is this. I bought a keystone passport 2021 and found a bunch of bubbles. Was told by keystone it was not a problem, but considering the other issues I've found not sure I believe them.
I will never buy another keystone
kclady0525 is offline   Reply With Quote
check, roo, roof
