Old 03-03-2020, 02:35 PM   #1
Removing old caulk tips
I need to do some maintenance to the 5th wheel. Iím going to re-caulk the seams around the outside of the unit. What methods/tools have others used to remove the old caulk without doing damage to the outside wall of the RV? Thx for any advice.
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 03-03-2020, 02:42 PM   #2
Thurman's Avatar
What type outside walls do you have, metal or fiberglass? IF fiberglass I would be careful not to scratch the fiberglass while removing any caulk. Tools: 1) a heat gun. You might get by with a hair dryer but I have not had good luck with those warming up caulk. Use the heat gun to warm up the old caulk so that it will be easier to remove. 2) A painters putty knife. These are not just flat on the end, it will have a sort of "hook" to help get into seams to remove old caulk/sealant. 3) Lexel sealant to replace the old caulk. Lexel works better than silicone on outside surfaces of RV's and can be removed later. 4) Elbow grease, and you will need plenty of it.
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 03-03-2020, 03:44 PM   #3
I guess it is not caulk but a product called Geocell. I think they use it at the Cedar Creek factory and Orvin gave me a tube when I visited his shop. Pretty hard right now.
I have fiberglass. I guess I can try the heat gun technique carefully. Thanks for the reply and tips..
Old 03-03-2020, 04:26 PM   #4
This is what I have. Orvan gave me this tube when I visited. He re-sealed using this...
Old 03-03-2020, 04:51 PM   #5
Get a set of auto trim tools with the wide scrapers and you won't damage the skin if you use those.
I just changed a baggage door on our RV and the caulking was really hard. I used a chisel to break a seam in the middle of it without touching the siding or the door frame, and then used the scrapers to lift it off the siding. It came off clean once I did that.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 03-03-2020, 05:02 PM   #6
Just curious but has anyone ever used an oscillating multi-tool like a Fein, Dremel, Rigid, etc to remove caulk. I see calk removing tools sold for them. The blades on these tools oscillate back and forth very little but quite fast and it would seem that they could be controlled well enough to only cut the calk without damaging adjoining surfaces.
Just curious.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 03-03-2020, 05:08 PM   #7
I have a couple of those and they're great for lots of tasks, but one slip and you'd have a gouged wall or roof.
I have used the smooth putty knife blades on them to remove caulking around the house and they work great, but I'm not brave enough to try it on the RV where paint won't hide it.
Gotta go campin!
Old 03-03-2020, 06:10 PM   #8
It has not been mentioned yet in this thread. So... never use silicone based caulk anywhere you will need to remove it and replace with fresh caulk. Not even fresh silicone will stick to cured silicone.
Hobienick
2020 Rockwood Roo 19
2012 F150 SuperCrew Ecoboost
hobienick is offline   Reply With Quote
Old 03-04-2020, 06:16 AM   #9
Have used the caulk removal tools at the hardware stores, there are metal and plastic. For the residue GooGone makes a caulk removal spray.
c3prret is offline   Reply With Quote
Old 03-04-2020, 07:45 AM   #10
spicercars's Avatar
Do not use a multi tool you will do more damage trying to remove the caulk. What I did on mine was waited for a sunny day and let the sun warm up one side of the unit. I used plastic tools that I found at Menards and it really worked well. Took me a couple of days to do the whole thing but it turned out great. Lots of patience.
2020 Wolf Pack 23GOLD15
1998 Dodge Ram 3500 Cummins Diesel Dually
spicercars is offline   Reply With Quote
Old 03-04-2020, 01:33 PM   #11
Applying GooGone to caulk will soften it and make it easier to remove. It won't hurt the fiberglass.
PenJoe is offline   Reply With Quote
Old 03-04-2020, 01:47 PM   #12
rollscanardly's Avatar
For removing old sealants, I've had the best results using a soldering gun with a rope cutting attachment.
See Post # 36...
https://www.forestriverforums.com/fo...-125403-2.html
https://www.parts-express.com/weller...g-gun--372-072
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
rollscanardly is offline   Reply With Quote
Old 03-04-2020, 01:47 PM   #13
DRM796's Avatar
This might be a side bar but I am correct in saying the products like Geocel and Proflex will adhere to itself?
2019 Alpine 3700fl
2016 Chevy Silverado 3500HD DRW High Country
"Best money we ever wasted"
2012 Wildcat 313RE traded in 5/2018
DRM796 is offline   Reply With Quote
Old 03-15-2020, 01:02 PM   #14
Drm796,
Geocel is the company that makes Proflex. Looking at the tube directions now, it says to apply to clean dry surface free of any foreign matter.
It is all I use on the gel coated fiber glass vertical surfaces of my MH. It will adhere to itself following the above precautions but I only overlap recent or fresh work (at least let it be skimmed over which doesn't take long). But, for the most part because I tool using a finger dipped into a heavy concentration of Dawn with water, I find to get the smoothest tooling I need the old stuff gone.
To remove Proflex you can usually grab an edge and it pulls out in long pieces. Dont use a heat gun, there's too much plastic trim pieces which will melt, including your roofing. A hair dryer isn't necessary either for Proflex.
To tool, apply a thin bead a foot or two at a time and lightly tool as described above. Dont try to push Proflex into a seam, it just makes for a sloppy caulk job.
Chris
2006 Sunseeker 2860DS Ford V10 5 sp. Torq-Flite w Tow/Haul
Winegard T4 In Motion Satellite Dish
Furion Rear Camera, RecPro 70" Recliners
Mohawk Luxury Vinyl Plank Flooring
2013 AWD Acadia Denali, Blue Ox Equipped
ChrisParise is online now   Reply With Quote
Old 03-15-2020, 02:54 PM   #15
DRM796's Avatar
Originally Posted by parise View Post
Drm796,
Chris
Good info. Thanks for sharing Chris
2019 Alpine 3700fl
Old 04-02-2020, 10:44 PM   #16
Hclarkx's Avatar
Somewhere years ago I got a supply of bamboo paint stirring sticks. They are about 5/8" wide, 1/8" thick, and a foot long. I use my bench grinder to put a chisel end on them for scraping stuff off of plastic or other damageable surfaces. The bamboo is hard and holds an edge well, but not hard enough to dig into plastic unless the plastic is very soft which it usually is not. I re-sharpen as needed though the edge holds well. Before I ran into the bamboo paint stirring sticks, I used oak that I cut into strips of about the same dimension and made scraper out of them.
2020 GMC Denali 2500HD Crew 4X4 Gas 6.6L
2015 30' 8280WS Rockwood Ultra Lite - lifted 3"
Solar plus LiFePO4 and 12V fridge.
Hclarkx is offline   Reply With Quote
caulk
