05-21-2022, 05:39 PM
Removing Tape Adhesive From Front Cap
I had my trailer in for routine service and repair this week. I picked it up Thursday and discovered someone had taped the service number card to the front cap with packing tape instead of taping it to the LP gas tank cover. I raised a stink with the owner and he said it will wash off. Really!?!?
Besides never using that bunch ever again, how do you get this mess off of the front cap without damaging it or the finish? Any advice will be much appreciated.
05-21-2022, 05:49 PM
WD-40
05-21-2022, 06:02 PM
Originally Posted by MR.M
WD-40
Won't that damage the finish?
05-21-2022, 06:08 PM
I would think so.
2023 Dynamax Force 34KD
-Demco Air Force One
2005 Toyota Tacoma 4x2 Crew Cab
-Remco 2pc Drive Shaft w/Disconnect
-Blue-Ox Avail Tow Bar and Baseplate
05-21-2022, 06:19 PM
A better and more complete answer can be found here. I seem to have been mostly wrong.
https://dftowel.com/post-will-wd-40-...e-to-find-out/
05-21-2022, 07:49 PM
I recall reading somewhere on this forum how to do this but can't find the thread.
2015 Palomino SolAire 20RBS
2022 Silverado 2500HD LT Duramax 4WD
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 26 days; 2019: 8 days; 2020: 0; 2021: 10 days.
05-22-2022, 06:46 AM
Check out Goo Gone. We used it on quite a few things over the years. Softens and removes the glue residue but has not damaged any of our paint so far.
Don’t have any handy to read the label but may be an option.
2014 3051S - First RV for us
05-22-2022, 07:59 AM
Believe it or not - PEANUT BUTTER. The oils in it soften the adhesive to the point it can then be wiped off. A little soap and water after that and you're done.
2018 Georgetown XL 377TS
2020 Jeep Gladiator "Toad"
CAMPING (n. CAM-ping) - When you walk the dog in your pajamas with a cup of coffee in one hand and a bag of dog poop in the other while striking up a conversation with total strangers.
05-22-2022, 09:25 AM
.. and there you have a use for your recalled Jif pb!
2023 Coachman Apex UL 243FKS, 2016 F150
05-22-2022, 10:00 AM
NO it will not wd-40 works well at removing adhesive and does not damage the finish.
05-22-2022, 10:05 AM
Just make sure you wear gloves so you don’t get salmonella [emoji3]
05-22-2022, 10:24 AM
The active ingredient in WD-40 is fish oil, so no harmful effects.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
05-22-2022, 10:51 AM
X2 on Goo Gone...even takes vinyl glue off plexiglass without harm.
05-22-2022, 11:43 AM
WD-40 and GooGone both work well. The absolute best is 3M Adhesive remover, at about $15 for a large spray can. This is the best for heavy tough glues, like used on tapes or decals.
2019 Sunseeker 3010DS
160w/9A roof top SOLAR
Playmaker DISH w/ Wally
Canadian Member
I used WD-40 on the ABS roof of our old Coleman popup with no I’ll affects. I’ve used Goo Gone on the fibreglass wall of a travel trailer with no I’ll affects.
05-22-2022, 02:23 PM
I had a tire blowout on a painted aluminum trailer. Tire pieces slapped the side of the trailer and left black marks. Goo Gone did a nice job of removing the black tire marks but also began to remove the paint.
05-22-2022, 03:58 PM
Even better than Goo Gone is Contractor's Solvent. It will remove ALL adhesive remains quickly. It is the best for removing labels off of glass containers you want to save. It will also remove latex paint and caulk!
05-22-2022, 04:04 PM
Thanks for all of the great suggestions and ideas! 👌👍
05-24-2022, 08:40 PM
Heat gun and plastic scraper?
05-24-2022, 10:11 PM
Now there is an accident waiting to happen . really to get adhesive off A heat Gun bad idea !
