Old 03-23-2018, 06:27 PM   #1
Ripples in roof
Hey all. I picked up a Sabre 36bhq last weekennd. I should have looked at the roof when I took possession, but I didn't. I know, I know. Anyway, the roof has 'ripples' in it. The pictures show it better than I can describe it. Is this how it's supposed to look? Seems like this could lead to problems in the future. Thanks for any guidance.
Skip12 is offline   Reply With Quote
Old 03-23-2018, 06:43 PM   #2
Scoundrel
HangDiver's Avatar
No photos.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 03-23-2018, 06:48 PM   #3
Thanks. Hope the upload worked this time.
ID:	165950   Click image for larger version
Old 03-23-2018, 07:19 PM   #4
Mountainmanbob's Avatar
There is not a wire under there -- is it?
Don't look right.
Could cause problems later?
M-Bob
Mountainmanbob is offline   Reply With Quote
Old 03-23-2018, 07:30 PM   #5
No. There's no wire. It's at regular intervals as if the roll were flat and roughly 4 feet wide.
Old 03-23-2018, 07:42 PM   #6
Could be an uneven surface with minor membrane delamination which could become a problem down the road. Is the membrane loose or detached from the substrate at these locations.
Notime2go is offline   Reply With Quote
Old 03-28-2018, 09:16 PM   #7
It is the plywood seams. Mine looks the same. I just keep an eye on it and nothing has changed.
ProCharger is offline   Reply With Quote
Old 03-29-2018, 10:29 PM   #8
Thanks ProCharger. You are correct. The seams are spaced out exactly 4 feet apart and span nearly the entire camper roof, side-to-side. How long have you been observing this on your roof? Anyone else observe this? It doesn't seem to be causing an immediate issue but I'm pretty concerned about long term impact.
Here are a couple more pictures.
Thanks again.
Old 03-29-2018, 10:33 PM   #9
Pics attached this time.
ID:	166588   Click image for larger version
Old 06-08-2018, 10:47 PM   #10
Mch5jdm's Avatar
Any changes?
Letís go camping!
Mch5jdm is offline   Reply With Quote
Old 06-08-2018, 11:30 PM   #11
No, no changes so far but I dont expect any sudden changes. I'm just concerned that the roof wont last as long as it's supposed to. At this point, I think there will be no change until next winter and will hope for the best.
My dealer checked with Sabre who said this is 'normal'. I'd prefer if they said 'not normal, but not a problem' because it doesn't seem normal.
Thanks a lot for checking in and I'll update this thread if there are any changes.
Old 06-16-2018, 02:32 PM   #12
wayne nichols's Avatar
Looks to me like they replaced to roof a some point and when they reinstalled the rubber they didnt pull all the ripples out. this could be an issue. I have seen camper going down the road with a big bubble where air is getting under the rubber roof. If it was me I would get it checked by a dealership.
Leah, Wayne, Max & Beignet
2008 Ford F-450 King Ranch 4X4 6.4L
2008 Cardinal 30LE
wayne nichols is offline   Reply With Quote
roo, roof
