Old 06-20-2021, 11:49 AM   #1
Roof concern?
So just looking over the roof on our 2021 wolf pup as I do occasionally. I noticed that along a stretch of one side itís almost as if the white roof material (rubber?) is almost lifting/bubbling up? When I push down on it thereís a little bit of give as if a little air has made its way between the rubber and whatever is below it (guessing cheap plywood the way these things are made lol). Noticed it more with the warmer weather. There doesnít seem to be any breach of the material, no holes or tears anywhere. Itís pretty minimal, attached a picture and circled the area, little difficult to see. Just wondering if I should keep an eye on it, or attempt to apply some sort of additional rubber roof coating to the area. Obviously want to avoid any sort of future water damage. Thanks!
Outdoorliving is offline   Reply With Quote
Old 06-20-2021, 12:03 PM   #2
rsdata's Avatar
I have read on previous posts that slight bubbling of the ( probably TPO) rubber roof material is almost a given.
So far what you describe is nothing to worry about.
Sometimes roof sections coming unglued can be sever, as when negative air pressure at highway speeds lifts up whole sections of the roof in hot weather.
You can either keep an eye on it to make sure it does not get worse. or I would also think about getting some Eternabond Tape to apply across the width of the bubble overlapping at least a few inches side to side to help reinforce that area from coming up while driving. The tape will not re-glue the bad spot to the roof, but will give it more strength to resist lifting while traveling.
2014 Shamrock 183
Old 06-20-2021, 08:33 PM   #3
Awesome thanks for the tip, just did a search for the tape. Certainly canít hurt to have on hand.
Old 06-21-2021, 08:01 AM   #4
rsdata's Avatar
I actually did a write-up on the use and application of Eternabond as preventive maintenance on the roof...
Instead of fooling with self-leveling Dicor and inspecting your roof quarterly putting new Dicor down do it once with Eternabond and inspect yearly cause the Eternabond does not have the shrinkage problems that a liquid sealant with solvent in it has.
if you are interested you can find it here
https://www.forestriverforums.com/fo...nce-90060.html
2014 Shamrock 183
Old 06-21-2021, 08:10 AM   #5
The edges of the roof will have tape under the membrane running that full length for an added layer of protection. This will usually be something like duct tape. Itís purpose is to simply keep the edge of the membrane from wearing through because itís against that rough edge. So itís very common to see some bubbling along there since the membrane wonít really be glued down along that tape seam.
Old 06-21-2021, 07:29 PM   #6
Awesome, thanks Iíll take a look.
Old 06-21-2021, 07:31 PM   #7
Interesting thatís good to know! Thanks!
Old 06-23-2021, 02:48 PM   #8
My 2020 does the same thing. I have about 4 small bubbles on the roof when I checked it the other day. I contacted a reliable RV repair guy that I know and he says this is normal with rubber roofs. He said just keep an eye on it. I have eternabond tape in the trailer for my roof emergency needs
2019 Ram Big Horn 6.7 Cummins
2020 Rockwood Ultra Lite 2304DS
RobRockz is online now   Reply With Quote
roo, roof
