Old 07-14-2020, 08:47 AM   #1
HK3
Roof questions
Couple issues after going up on the roof...
1) finding these little bubbles that havenít popped, but I see them on the roof in a couple places and something similar on the slide out top. They are around the edges as well. Is this something I should cover up or just let be? What happens next?
2) my insert trim on the front seam came off. At the top it looks like it was just gooped on with sealant. I purchased some replacement trim from amazon and some brackets to screw in to hold it down. Any suggestions on what sealant to use to cover that application?
3) I have a small tear in my roof, as shown in the pictures. Open to any suggestions there as well.
Thanks in advance for the help!!
HK
ID:	233885   Click image for larger version
ID:	233886   Click image for larger version
ID:	233887   Click image for larger version
ID:	233888   Click image for larger version
HK3 is offline   Reply With Quote
Old 07-16-2020, 05:20 AM   #2
The bubbles are likely some off gassing from the adhesive. I would keep and eye on the but not worry too much at this point. If they continue to grow you will want to have someone look at it for a possible repair.
I would use Dicor self leveling sealant over the trim and for general maintenance of the sealant. Some will use Eternabond tape over all sealant as extra sealing. Many are very happy with it.
For the tear use the afore mentioned eternabond tape. You can get it in different widths and lengths. Cut a piece to fully cover the tear and create a border around it.
TheMcBees is offline   Reply With Quote
Old 07-16-2020, 05:37 AM   #3
Mike223's Avatar
It's hard to beat Eternabond tape for any repairs.
Mike
Mike Gray
Forest River Wildwood
2018 230BHXL
2015 Sierra SLE 5.3 V8 4x4
Mike223 is offline   Reply With Quote
Old 07-16-2020, 10:02 AM   #4
HK3
Mike
Roger that, thank you both...itís the next thing in my amazon cart!
roo, roof
