Old 12-15-2020, 12:15 PM   #1
swj
Roof Replaced and
My original roof FRiver put on my 2017 Surveyor was a thick, solid, no seams, hard rubber like material with a smooth/slick finish. It cleaned up easy. No leaks.
Roof was damaged/new roof put on. The 1 year old current roof is different.(?) The roof surface is a lightweight, no seams, thinner material that has a slight textured feel to it. And you can see all the taped over wood overlay joints, under the thinner material. Lots of air bubbles and at least one screw head backing out. No leaks.
Any comments on why current roof is so different. EPDM of TPO?
swj is offline   Reply With Quote
Old 12-15-2020, 12:22 PM   #2
It's thinner because it's cheaper. Installed by a dealer I assume?
wet in washington is offline   Reply With Quote
Old 12-15-2020, 12:35 PM   #3
swj
roof replace
yes
Old 12-15-2020, 01:38 PM   #4
Originally Posted by swj View Post
yes
They will put the cheapest material they can put on to increase their profits. I see you said there are air bubbles in the roofing already after a year. That says it was improperly installed. You get what you pay for.
roo, roof
