Old 04-20-2020, 06:33 AM   #1
Dave Lyon's Avatar
Roof Sealing - Dicor
I checked out my trailer this weekend (what else is there to do) and noticed that the caulking (Dicor) on the roof is showing signs of minor cracking.
The trailer is a 2012 with original seams and Dicor.
Can I apply self-levelling Dicor directly over the existing or does the existing have to be removed?
much appreciated.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 04-20-2020, 06:48 AM   #2
007matman's Avatar
I've put it over the top of the old for minor repairs (after I've cleaned it well). However, the seal is only as good as the product below. Therefore, if you have a lot of it that's failed you'd be ahead to completely remove the old and lay down a new bed.
A heat gun (light heat.. any more will damage the roofing) to soften and a putty knife makes quick work out of it.
Don't forget to clean thoroughly between.
007matman is offline   Reply With Quote
Old 04-20-2020, 07:45 AM   #3
WFD
Lots of talk on here lately of Eternabond tape, and lots of glowing reviews of the product. You may want to consider that as it sounds like a more permanent fix.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 04-20-2020, 08:15 AM   #4
Just as confused as you
Scrapper's Avatar
Originally Posted by WFD;2309502[B
]Lots of talk on here lately of Eternabond tape, and lots of glowing reviews of the product[/B]. You may want to consider that as it sounds like a more permanent fix.
Eternabond has been talked about on the forum for several years because it works, works great and has a 10yr warranty when properly applied.
https://www.eternabond.com/default.asp
Richard & Jill
Camping since 1989, seasonal since 2000
I deserve hazard pay when camping with my relatives.
Old 04-20-2020, 08:18 AM   #5
Mike223's Avatar
And you don't have to take off the old Dicor
Mike
Mike Gray
Forest River Wildwood
2018 230BHXL
2015 Sierra SLE 5.3 V8 4x4
Mike223 is offline   Reply With Quote
Old 04-20-2020, 01:42 PM   #6
U.S.ArmyVeteran's Avatar
Does Eternabond tape conform to bumps, valleys, and grooves etc. Can it be stretched or something when applied??
Thanks.
U.S.ArmyVeteran is offline   Reply With Quote
Old 04-20-2020, 01:47 PM   #7
RudysWorld's Avatar
Everything I have read from dicor and roof fixture manufacturers says clean well and it easily comes off take off otherwise after cleaning go over with denatured alcohol for fiberglass roof and use dicor over the bad areas. Just did my 2011 this morning. Good Luck!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 04-20-2020, 02:30 PM   #8
Scrapper's Avatar
Thanks.
Eternabond does have some give to it so it will conform if the anomaly is not too radical. If the bump is ragged you can shave some off with a razor blade or utility knife blade. You don't need to remove it all down to the fiberglass cap or EPDM/TPO. Use a 2" steel or hard rubber roller to roll it down and you will be fine.
File Type: pdf EternaBond_Installation_Instructions.pdf (134.2 KB, 48 views)
Richard & Jill
Old 04-20-2020, 02:44 PM   #9
Dicor comes off quite easily with a heat gun and putty knife. I highly recommend removing it before applying Eternabond. It will look much better and the Eternabond seal job will be as good as you can get it.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 04-20-2020, 11:39 PM   #10
Thanks, Appreciate that info.
Old 04-21-2020, 07:21 AM   #11
Dave Lyon's Avatar
Thanks for the responses. you've given me some things to consider...Ö.still not sure what approach I'll take.
Dave, Southern,ON
Old 04-21-2020, 08:11 AM   #12
DouglasReid's Avatar
When we first got our camper it was 3 years old. We were camping one rainy weekend and I found a slight drip in the middle of the living area.
After pulling one of the ceiling panels loose I found the source of the leak It was in the middle of the roof. An inspection of the roof revealed two of the roofing panels were about 1/2" apart tnd the rubber roofing was sagging in between the two.
I never did find the pin hole, but I solved that and any future issues by purchasing some Gaco Flex Liquid Roof Tape. I bought a gallon of it for around $75 and only used 1/2 of it.
https://www.roofcoatingsupply.com/Ga...AaAuE0EALw_wcB
It applies easily with a brush and has a guarantee of up to 50 years. It is also suitable for application over a rubber roof.
I applied it over that entire seam area and around every penetration of the roof, both sides and both ends. I simply covered over the Dicor which all seemed to be in good condition (After thoroughly cleaning it of course)
7 years on nary a single leak and the material is still in as good of condition as the day I applied it.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
roo, roof, seal
