Old 04-23-2020, 08:08 AM   #1
Roof sealing question
Not sure what to do in the back two corners of my Surveyor 24 sport with the 2001 flat roof. The two corners have a bad design to trap water, I tilt the camper to the left rear corner when camping but Iím limited to how much so I donít effect sink and shower drains. This is how it was delivered from the factory.
Should I keep adding to whatís there after I clean it or try too scrape it down and re apply? Anyone have any suggestions to limit the water trap?
The camper is under cover when not camping so not concerned with storage.
ID:	227488   Click image for larger version
ID:	227489   Click image for larger version
ID:	227490   Click image for larger version
dalenelson is offline   Reply With Quote
Old 04-23-2020, 09:14 AM   #2
SeaDog's Avatar
I think I would cut that rail at the corners just enough to cement in a gutter spout to allow the water to drain. gutter spouts 2 for 7 bucks. Just one guys idea
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-24-2020, 08:04 PM   #3
My 2 cents. Just keep up with your regular roof and joint maintenance for your unit. My rv roof has a low front corner and retains a small pool of water until it evaporates, sometimes takes a day or longer.
2006 Sunseeker 2860DS Ford V10 5 sp. Torq-Flite w Tow/Haul
Winegard T4 In Motion Satellite Dish
Furion Rear Camera, RecPro 70" Recliners
Mohawk Luxury Vinyl Plank Flooring
2013 AWD Acadia Denali, Blue Ox Equipped
ChrisParise is offline   Reply With Quote
Old 04-24-2020, 09:25 PM   #4
Just as confused as you
Scrapper's Avatar
Is this a TT you bought new in 2001 or a "new" to you used trailer?
Reason I ask is that caulking doesn't look like anything FR has used in years, if ever. It looks like someone who had no clue found some kind of putty and plopped it on.
If there is not any structural damage, rotten roof plywood or walls you should get some Eternabond tape and apply it following manufacturers directions. If done right Eternabond will last at least 10 years. All the info you need can be found here, https://www.eternabond.com/. You can order from there too.
Doing a search on these forums will net you lots of threads from other members who have used Eternabond for preventive maintenance or repairs.
Richard & Jill
Camping since 1989, seasonal since 2000
I deserve hazard pay when camping with my relatives.
Old 04-24-2020, 09:57 PM   #5
Doppleganger's Avatar
https://chemlink.com/product/duralin...rpose-sealant/
That's what https://www.rvroofinstall.com/ recommended as a quality sealant that has good flexibility. They recommended using a membrane primer on the surface before applying it. Of course, you will have to remove the sealant on the roof, but that stuff should last a long time.
2016 Jeep Grand Cherokee Overland 5.7
2020 Coachman Apex Nano 187RB Outfitter & Off-Grid
Doppleganger is offline   Reply With Quote
Old 04-24-2020, 10:46 PM   #6
rsdata's Avatar
ANSWER: 6 inch wide Eternabond tape, lapping over what is on there over to clean roof and up the side of the lip... installed correctly you will not need to worry about it for at least 10 years. Adding a gutter as was suggested not a bad idea also to eliminate the standing water.
Just clean whatever you put the Eternabond well before installation to assure good adhesive contact. Don't take my word for it... Buy one small roll of Eternabond and work with it and you will convince yourself of it's superior sealing qualities.
eternabond dot com
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 04-25-2020, 06:52 AM   #7
tapex's Avatar
eternabond dot com
X2
2016 Coachmen Apex 250RLS Ultra Light
'19 Ram Big Horn Sport Longhorn
tapex is online now   Reply With Quote
Old 04-25-2020, 08:23 AM   #8
X3. I wouldn't disturb what's there beyond a light cleaning. Unless you have leaks, notice wet walls, carpeting, musty odors which indicate dampness. Then follow up with eternabond.
Originally Posted by tapex View Post
X2
Old 04-25-2020, 12:44 PM   #9
Sorry itís a 2011 Iím not the original owner, the sealant is self leveling Dicor.
Old 04-25-2020, 02:49 PM   #10
Scrapper's Avatar
Originally Posted by dalenelson View Post
Sorry it’s a 2011 I’m not the original owner, the sealant is self leveling Dicor.
It doesn't look like the self-leveling Dicor I've ever seen. Go with the Eternabond and do as rsdata suggests.
Richard & Jill
Old 04-25-2020, 03:32 PM   #11
Three agreements from me...
1. It doesn't look like any factory sealant I've seen.
2. That is a bad design.
3. Eternabond it with wide material tape and you won't have a worry for many years.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 04-25-2020, 11:12 PM   #12
dbledan's Avatar
I would combine a few of the good ideas.
1. Cut a channel to drain it.
2. Add some dicor to level things out and get the roofline over the ridge making sure there is still a drain channel and let it harden. Then cut the dicor flush with a blade to level it out a bit. Note that I am suggesting using dicor as a filler not a sealant in this case but it can do double duty. Other fillers could be used if safe for the epdm roof and completely covered in etrnabond.
3. Cover with eternabond to the corner.
Good luck and take pictures of your solution.
dbledan is offline   Reply With Quote
roo, roof, seal
