Old 10-17-2019, 02:32 PM   #1
Oldbears's Avatar
Roof vent cover patch recommendations?
We just spent the week camping under oaks and got bombarded with acorns. One of which punched a hole right through the plastic roof vent cover. Does anyone have a recommendation for a good, waterproof, patching material that would be suitable to adhere to this type of plastic. I'm not interested in DUCT TAPE, thank you! And not interested in replacing the cover for this small amount of damage. Thanks in advance for any serious recommendations.
2019 E-Pro 14fk
"Some people go camping to relax - you should try it."
Oldbears is offline   Reply With Quote
Old 10-17-2019, 02:38 PM   #2
Fulltime family RVer
My first response would be to just replace it. But you've nixed that plan.
My next response would be Gorilla Tape, but that's just a stronger, bigger, bad-asser cousin to Duct Tape. So that's out.
Is Eternabond tape far enough away from duct tape? Still an eyesore but will hold.
And lastly, I might consider awning tape. It's sort of see-thru and should be less noticeable.
Old 10-17-2019, 02:50 PM   #3
A32Deuce's Avatar
Clear Flex Tape.
A32Deuce is online now   Reply With Quote
Old 10-17-2019, 03:14 PM   #4
007matman's Avatar
You should replace it. They make replacement covers. That vent cover is the only thing keeping the inside of your trailer dry. Why would you want to risk that with a patch?
Get some maxxflo vent covers after that and it'll protect the covers from further damage (they're more durable).
007matman is offline   Reply With Quote
Old 10-17-2019, 03:18 PM   #5
007matman's Avatar
Like theseClick image for larger version
ID:	217495Click image for larger version
Old 10-17-2019, 03:20 PM   #6
Yep... don't skimp on this one.
Replace it (cheaper than you might think) and then get vent covers.
Days Camped: '17=30 '18=51 '19=58 '20=55
Old 10-17-2019, 03:41 PM   #7
D W
D W's Avatar
If a falling acorn punctured it then that cover has had it. It's only going to get worse. I would just slap some tape on it (carefully!), and get a new cover on order from Amazon or Walmart ASAP.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 10-17-2019, 03:53 PM   #8
I would replace it too. If an acorn broke it, its brittle and needs to be replaced.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 10-17-2019, 05:19 PM   #9
Roof vent
I had a vent damaged by hail. The screen caught the pieces so Ibrepaired it with two part epoxy that looks like a syringe. That being said a new vent can be had for 18 bucks. Hey
hreimers is offline   Reply With Quote
Old 10-17-2019, 05:50 PM   #10
bbbeebop's Avatar
I would suggest replacing it. If it was a fantastic fan, then you may find it has a lifetime warranty’. Even so they are not very expensive!
bbbeebop is offline   Reply With Quote
Old 10-17-2019, 06:18 PM   #11
Oldbears's Avatar
Thank you for those responses that stayed on topic, and the thoughtful responses of others.
As someone who spent several years of full timing in the Florida sun, I am keenly aware of what a brittle vent cover looks like. And I have replaced said damaged covers in my lifetime. But I am not interested in replacing a three month old cover with a clean acorn bullet hole, and no other damage. A patch is a suitable solution for this damage.
I am interested in products or materials folks have had good luck with that may be something that I haven't thought of yet. The top of my list is using materials from a high-end canoe patch kit that I have. I'm just currently researching the compatibility of the adhesive....
For me, a small repair is a better option than adding another chunk of plastic to the landfill.
2019 E-Pro 14fk
Old 10-17-2019, 06:25 PM   #12
bbbeebop's Avatar
You’re kidding right?? Might try an epoxy patch!
Bob & Laurie w/Missy
Sayre, PA
2016 Flagstaff Micro-Lite 21 DS
2015 Ford Explorer
Old 10-17-2019, 06:29 PM   #13
Vent Patch
There's a product called "Sail Tape". It's clear and originally made to patch saile on boats. Its strong and will stck to the vent plastic. You can usually find it at Camping World as a patching material for awnings.
JimMorrell is offline   Reply With Quote
Old 10-17-2019, 07:09 PM   #14
D W
D W's Avatar
Go ahead, put a canoe patch on it, and let us know how you make out.
2016 Salem 27RKSS
Old 10-17-2019, 07:18 PM   #15
If an acorn put a hole in it it is time to replace it. After a few years in the sun they get very brittle. Hate to see a load of snow finish it off if you live where it snows.
I just saw that it is not old. Use a clear plumbers epoxy.
atemplesr is offline   Reply With Quote
Old 10-17-2019, 07:30 PM   #16
DouglasReid's Avatar
Ive got to hand it to you, you presented a problem and then, even before any suggestions were made, you nixed most every possibility.
Sounds like you already had your mind made up and were most likely looking for someone to suggest what you had already made your mind up to do.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 10-17-2019, 08:58 PM   #17
Oldbears's Avatar
Bingo!
Thank you for this suggestion! It is exactly why I posed the question to begin with; to hear material suggestions from others that I hadn't thought of myself.
I happen to have an excellent two part plumber's epoxy that will be perfect for this SMALL patch. It adheres to anything, waterproof, and so sturdy it should outlast the life of the cover. Shouldn't take me more than 10 minutes and will cost me ZERO dollars. Thanks again @atemplesr, and to everyone that KINDLY suggested various patching products.
2019 E-Pro 14fk
Old 10-17-2019, 09:21 PM   #18
Stank Bait's Avatar
Wow! This is what keeps me coming back.
2013 Flagstaff 831FKBSS
Stank Bait is offline   Reply With Quote
Old 10-18-2019, 12:51 AM   #19
Vent cover repair
Epoxy will work if the hole is small or you can apply it in increments.
But I wonder if clear awning repair tape might not be easier and cleaner. It will stand up to the sun, is watertight and easy to work with. I used it to repair a 6 inch tear in my awning that was right next to the seam and at the end of the awning tube. The tape is really inconspicuous. After 3 years it is holding up perfectly even though it is applied in an area subject to high tension.
Good luck.
plymaniac is offline   Reply With Quote
Old 10-18-2019, 08:31 AM   #20
Oldbears's Avatar
Good luck.
Thank you plymaniac. I've been thinking about adding awning tape to my tool kit anyway, so might give it a try on this small hole.
2019 E-Pro 14fk
cover, roo, roof, vent
