RV Corner Separation
The corner of my RV is separating. I tried pushing it together and then using an adhesive, that didn't work.
I don't know whether to attempt to put a long screw from the side, or back would hold it in place, or go inside the RV, remove the built-in cabinet in that corner, cut away a little of the wall and screw through a toe plate (if there is one) into the decking.
Does anyone have experience with this and how did you remedy it?
I'll try to post pictures.
2020 F250, 7.3 gas, 34 ft. Fifth Wheel, SOB
