Old 01-28-2021, 06:11 PM   #1
swj
rv flex armor
Anyone had any experience on rvroof.com and their rv flex armor spray on roof treatment? There are a few knock off companies with similar names. I'm looking at the rvroof.com company. Ben around for 20 years.... Everything I read is a positive. Great replacement for PVC, TPO and EDPM roof system. No more piles of lap seal. NO MORE LAP SEAL. Clean look/slick fiberglass, as well as lifetime warranty for leaks thru material and where AC and other roof mounted hardware attached to roof.
Why haven't the RV mfg gone to this type of roof. TPO, PVC, and EDPM all seem to have a 5 year life because of the piles of lap seal needed to leak proof ACs and stuff on the roof??
swj is offline   Reply With Quote
Old 01-29-2021, 02:08 AM   #2
Retired FF
wrogers's Avatar
Had mine done by RVRoof in Florida. Best investment for my rig I ever made.
Tougher roof now, zero maintenance, stays cleaner.
2019 Heritage Glen 356QB
2021 Ford F450 DRW 4wd
wrogers is offline   Reply With Quote
Old 01-29-2021, 10:36 AM   #3
Nick Danger's Avatar
Minimum charge
Contacted them per phone # published on their website. Very nice conversation and sounds like a quality product but minimum charge is $3650. That's why the industry as a whole isn't stampeding to it. Appears that after a cost benefit analysis smaller units aren't cost effective. Just my opinion.
Retired USAF
2021 Freedom Express 192RBS
2020 F150 STX 4X4 w/Coyote V8
Centerline TS WDH
2004 Heritage Softtail Harley Davidson
Nick Danger is offline   Reply With Quote
Old 02-02-2021, 06:43 PM   #4
Retired FF
wrogers's Avatar
Here are a couple of pictures of my roof after RV Roof finished with it.
Again, I'm completely satisfied with the quality of the roof material as well as their workmanship.
The reason I had it done is because when the factory put the rubber roof on, there was a staple leg that was ticking barely through the rubber but caused an un-noticed pinhole leak. I found the leak when doing roof maintenance and saw an area of the rubber roof that looked "different". That was because of the OSB had started to swell there. Even after looking intently for why, it was very difficult to see where it was punctured. I actually found it by rubbing my hands over that area of the roof and "felt" the staple leg, but still was difficult to see.
RV Roof cut out the bad area of OSB and replaced it before coating the roof, and now I'll never have to worry about it again. The material is thick and durable. It seems a little pricey, but when I compared having the entire roof re-done with EPDM, it wasn't very much difference at all. so the thicker, tougher, easy to maintain roof was a no brainer to me.
Bill
ID:	247166   Click image for larger version
Old 02-02-2021, 07:01 PM   #5
swj
Flex armor!
Did you get the RV flex armor? The flex armor by RV roof company has you take your RV to them where they do the install at their/franchise indoor facility. Iím being told itís far better than the armor done by the installer that comes to you.
Old 02-02-2021, 09:05 PM   #6
Retired FF
wrogers's Avatar
Yes, I took it to them in Green Cove Springs, FL. It's not far from Jacksonville.
Their product is a spray on product, much like a spray in bed liner (it's thicker)
They remove all the A/C's, vents, skylights, etc. and prep the roof to spray. they then replace everything & put new vent covers & stuff. The final product is a 1 piece seamless layer that is very tough. They gave me a scrap piece when I picked up my rig & I whacked at it with a screwdriver and a knife and couldn't poke through it. Very impressive & gives me great piece of mind with my rig's roof.
If you go to their website RVRoof.com they will send you a sample of the product.
The company that comes to you uses a roll on product. I haven't seen it in person, so not sure if it is as thick or durable.
Old 02-03-2021, 09:00 PM   #7
swj
RV Flex Armor
THXS, having my RV Flex Armor roof put on this week. Having them spray over the skylight.
Old 02-04-2021, 07:37 AM   #8
Please post some pics of it when it's done?
We'll probably need to get ours done in a year or two, and I'd like to see the finished product.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 02-26-2021, 11:59 AM   #9
swj
done
Flex Armor Roof sprayed on. Looks great and is like a slight textured fiberglass like roof. NO LAP SEAL anywhere on the roof. The spray on material is sprayed on/up any flange that penetrates the roof. Skylight spray over. MAXXFAN mounting brackets on the roof surface sprayed over. Same process for TV antenna, ACs and anything penetrating the roof. NO MORE roof maintenance. NO more potential roof leaks. No more roof leaks due to lap seal failure. Bullet and HAIL proof roof.
This is my 3rd and final roof. Seems like Forest River and other trailer mfg should set up their own spray on roof facility and hit the trailers as they come down the line. The current EPDM, TPO, PVC roofs are all suspect and the lap seal failure is a real concern. Maybe that's by design.
Old 02-26-2021, 08:31 PM   #10
Rolling Chaos's Avatar
If they spray over the skylight won't that block all the light defeating the purpose of having it all all? I'm looking to do this to our new 5th wheel when the warranty is up. Do they remove the old material first?
Jim T
2021 Rockwood Signature 8298KS
2016 Ram 2500
Rolling Chaos is offline   Reply With Quote
Old 02-27-2021, 12:15 AM   #11
I sprayed white Plastidip over my skylight. The light still comes through and it cuts down on the heat.
Hobienick
2020 Rockwood Roo 19
2012 F150 SuperCrew Ecoboost
hobienick is offline   Reply With Quote
Old 02-27-2021, 09:58 AM   #12
I thought the heat is why they started putting in double layers of plastic glass. My last unit had it and our new one also. Keeps the heat out. Although it might help add a layer of protection for the top layer, in case of tree limbs and such.
Jim T
2016 Ram 2500
Old 02-27-2021, 11:52 PM   #13
I had to remove my inside layer. Moisture got between the layers and would not go away. When removing the inside layer I noticed the tape that held it in place had several large gaps. Concerned that it would just be a moisture trap again I left it off.
No problems with heat or moisture now.
Hobienick
Old 02-28-2021, 08:54 AM   #14
hobienick
I have not heard of that one happening. Worth watching out for in the future.
Jim T
2016 Ram 2500
