Old 11-11-2019, 10:41 PM   #1
The Newsoms's Avatar
Screw backing out under trim
2016 Cardinal
I have a screw backing out thatís pushing my trim off under the nose of my 5th wheel. Iím not sure what to do and was thinking about drilling a large enough hole to get a screw driver in there and tighten it back up. Iím afraid if I take the trim off to get to it, Iíll never get it back on correctly. Pictures are from both sides. Any suggestions?
ID:	219050Click image for larger version
Jimmy & Teresa Newsom
Now:2016 Cardinal 3825FL/2012 Work and Play 18EC
2012 Ford F-250
The Newsoms is online now   Reply With Quote
Old 11-12-2019, 09:43 AM   #2
Head Rambler
If you could be sure that it's just the one screw, I'd agree that drilling a small hole through the trim and tightening that one back up would work. But, what if it's more screws and you're just not seeing them yet.
I'd be inclined to take the trim off and inspect and tighten all the screws and then put the trim back on. It shouldn't be hard to get the trim off and put it back.
Gotta go campin!
Old 11-13-2019, 05:55 PM   #3
Thanks for your response.
2012 Ford F-250
Old 11-13-2019, 06:51 PM   #4
So I had a similar issue. It seems to me my trim covers under weíre floating and not anchored to the frame. So I drilled a new hole and used a shorter screw. This connects the cap to the under side trim panel.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 11-14-2019, 10:20 PM   #5
New to FR. Old to TT
If you do decide to take the trim off try to do when the weather or wherever the 5th wheel is warm. The warmer the better, the plastic trim will work much better.
Tall frog is offline   Reply With Quote
