Old 04-19-2016, 05:14 PM   #1
Screws showing around full perimeter of Fiberglass Roof
Hello,
I have a 2013 Sunseeker with a fiberglass roof. I finally climbed up on the roof today to check the integrity of the seals around the roof vents, skylights, etc.
I was surprised to see that screws were showing all around the perimeter of the fiberglass roof which were thru a trim piece which acted as a transition to the sidewall. Is it normal to see these screws all around the perimeter on the roof ? Do you think I should put a dab of Dicor sealant on each screwhead? I have not noticed any leaks so far.
Thanks in advance for your feedback.
herbmala is offline   Reply With Quote
Old 04-19-2016, 05:18 PM   #2
RSchleder's Avatar
What can it hurt to put a 'dab" on these screws?
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 04-19-2016, 05:19 PM   #3
I guess I am wondering if these unsealed screws are a factory oversight.
Old 04-19-2016, 09:06 PM   #4
Garrette's Avatar
1 yes, 2 no. Sealed mine with a dab.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 04-19-2016, 09:21 PM   #5
Thank you..
Old 04-20-2016, 04:52 PM   #6
Wandering's Avatar
Another thread suggested some come from the factory with all screws dicor'ed. Mine didn't so a little dab will do ya. Better safe than sorry.
Forester 2451s
Forester 2451s
Wandering is offline   Reply With Quote
Old 04-20-2016, 06:16 PM   #7
Canadian Member
Dicor, or for a more long term solution, Eternabond tape. Screw them back down first.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 04-20-2016, 08:41 PM   #8
Had the sae issue with our 2014 2500TS Sun Seeker Covered each one with a dab of dicor.. Firstly cleaned each one with mineral spirits. Looking at eternal bond also but dicor (lap sealant) should do the trick for now. Amazing that one spends all this money and gets to see a whole bunch of exposed screws on the roof.
Brandon2 2500TS
Sun Seeker 2014
brandon 2 is offline   Reply With Quote
Old 04-20-2016, 09:10 PM   #9
Dicor or Eternabond on exposed screws on Fiberglass Roof
I have been debating .....should I use the Dicor or Eternabond on the exposed screws on my fiberglass roof. Advice appreciated
Old 04-20-2016, 09:13 PM   #10
I used Dicor (lap sealant) it seemed to fill in the areas around the screw heads with no issues. Covered them completely.
Brandon2 2014
2500TS Sun Seeker
Old 04-20-2016, 09:16 PM   #11
Professional Curmudgeon
wrvond's Avatar
Eternabond should be considered a permanent fix, Dicor needs to be checked at least every two years. A 2 inch wide strip of Eternabond that reaches all the way around the perimeter of your roof is going to cost significantly more than a tube of Dicor.
I prefer Eternabond when sealing seams and screw heads.
2014 Coachmen Catalina 253RKS
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 04-20-2016, 09:26 PM   #12
I was considering cutting small squares from my roll of Eternabond to cover each screw. The roof is a textured fiberglass. Do you think this would work ( seal) ?
Old 04-21-2016, 06:09 AM   #13
Canadian Member
You'll be interested in this video.
http://youtu.be/GlY-qgv95BY
Old 04-22-2016, 07:49 PM   #14
Eternabond looks like a great product. I have 3 slide toppers on our 2500TS so there is no way I can get to tape the slides tops.. However on other parts of the roof I have seen where some people dicore the edges of the eternabond tape.
With this in mind we are back to inspecting the dicore lap sealant. On another point we have Maxx Airs on all of our roof vents so they do afford quite a bit of protection for the dicore around the vents.
Will order some on the net and cover those expose screws.
Brandon2
fiberglass, roo, roof, show
