Old 10-19-2018, 02:27 PM   #1
Self drilling screw source
See picture below. I’ve tried looking in various places.
What are these called? Look like some type of tamper evident indicator. These hold the plasticor belly on in nimerous places.
They are self drilling with hex head, “protected” by the plastic fingers surrounding the screw heads.
Maybe I am not sufficiently experienced.
Thanks in advance.
ID:	189570   Click image for larger version
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
Jeffjeeptj is offline   Reply With Quote
Old 10-19-2018, 02:41 PM   #2
A32Deuce's Avatar
That's to hold it up. Need that big washer to spread the load to keep it up.
A32Deuce is offline   Reply With Quote
Old 10-19-2018, 02:51 PM   #3
Thanks in advance.
Check on the Grainger web site.
Decon Blue is offline   Reply With Quote
Old 10-19-2018, 03:00 PM   #4
Many of the 'screws' are Ramset fasteners installed at the factory with a 22 caliber driver.
They are 'shot' into the frame and a bugger to get out.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 10-19-2018, 03:52 PM   #5
Thanks to 5Picker. I snapped one of the heads off and felt up inside. A nice pointy powder driven item.
Retired
Old 10-19-2018, 05:03 PM   #6
You can get self drilling screws with fender washers that closely match the diameter of the original fasteners.
Or you can just buy a RamSet and some fasteners to match!
Gotta go campin!
Old 10-19-2018, 05:59 PM   #7
rracer5's Avatar
A good quality neighborhood hardware store will more than likely have a good selection the self tapping screws & fender washers. Some stores may even have a small selection of screws with the washer included. I prefer Ace Hardware for stuff like that but, HD, Lowes & Menards should also have some.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 10-19-2018, 06:51 PM   #8
Fastenal for all your Fastener needs! Youroo! !
Old 10-20-2018, 02:19 AM   #9
RV There Yet?
IsleDog's Avatar
I was just going to suggest this! I work at the headquarters
IsleDog is offline   Reply With Quote
Old 10-20-2018, 05:17 AM   #10
World Wide Wanderer
wahoonc's Avatar
You will have better luck at an industrial supply house than most big box lumber yards. In larger towns there will quite often be a fastener specialty store. I use Triangle Fastener in the Raleigh, NC area and Tidewater Fasteners in the Norfolk, VA area. If you are in the KC area Dynamic Fasteners is a great choice. Fastenal is an option, but usually they have to order stuff in my experience.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 10-20-2018, 08:07 AM   #11
Geez, Amazon sells the screws and washers. Just remove one and measure it and buy the correct size screws and washers.
Search for self tapping screws for metal on Amazon and you will find what you need.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
chaps2018 is offline   Reply With Quote
Old 10-20-2018, 08:14 AM   #12
lesptr's Avatar
Fastenal. No better place for what your looking to get.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 10-20-2018, 09:05 AM   #13
https://www.mcmaster.com/tapping-screws
DES-1 is online now   Reply With Quote
Old 10-20-2018, 09:06 AM   #14
Always Learning
Any tricks to getting them out? I want to run some electrical but was dismayed to see these Ramsey fasteners.
Old 10-20-2018, 09:20 AM   #15
onetonford's Avatar
Actually I would go to ACE hardware. I went to Fastenal to buy Two 3/4 fine thread 3/4 inch long Grade 8 set screws Nope they would need to special order and minimum was ten. I went to Ace and they had them in stock.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 10-20-2018, 09:29 AM   #16
A32Deuce's Avatar
You could try a drill, but I think a angle grinder would do a faster job. Just grind the head till it will pry off or fall off.
Old 10-20-2018, 09:57 AM   #17
Those powder fasteners are hardened steel so you're not going to drill them out. Your best bet is to grind them off and then use a pin punch to punch them on through the beam if you want to reuse the holes.
Gotta go campin!
Old 10-20-2018, 12:47 PM   #18
Underbelly Fastners
You can get self-drilling hex head screws at Home Depot or Lowe's. To remove the ramset pins, use a pair of vise grip pliers, grab the head and turn the pin back and forth while pulling down. Once you get it loose slip a flat bar under the washer and pry it down while turning pin back and forth. Real easy once you get the hang of it.
Dan & Hélène
2017 Crusader 260RLD
2016 F350 6.7l Diesel, SWD
rvhat is offline   Reply With Quote
Old 10-20-2018, 12:51 PM   #19
I may have to take some of mine out. Will they screw out or will they have to be drilled out etc??
1984fireball is offline   Reply With Quote
Old 10-20-2018, 12:56 PM   #20
NMWildcat's Avatar
This...... Good advice
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
