Old 03-30-2021, 03:27 PM   #1
sjz
Slide-in pop-up camper roof damage buckeled
Hi I'm Steve, I'm new to the forum.
I am currently gearing up and getting back into doing some camping.. While inspecting my camper I found this new roof damage. I have no idea how this might have happened? The camper has been just sitting on saw horses for the last 15 years. I thought maybe it is due to thermal contraction over time. Does anyone know if this damage is repairable, and if so, how one might approach going about it?
I'm attaching a picture. Hopefully it shows up..
Name:	Camper roof damage.jpg
sjz is offline   Reply With Quote
Old 04-02-2021, 09:49 PM   #2
sjz
UPDATE:
Nobody responded.. So I decided to just jump into the project. I'm sharing what I learned in case someone else may have the same issue.
Inside the pop-up support frame tubing there are Torsion bars to relieve the load when cranking up the top. The constant tension at the anchor plates that are lag bolted in place eventually twisted and tore completely through the top. It didn't help that there was no metal reinforcement in there, only wood. I will post some pictures of the repair. You can see the large 2 1/2 inch wide steel angle bracket I had to make for each side. I will post so more pictures of the finished project..
ID:	251077   Click image for larger version
ID:	251078   Click image for larger version
ID:	251079   Click image for larger version
ID:	251080   Click image for larger version
Old 04-02-2021, 09:58 PM   #3
Looks like you are well on your way to having it ready for camping season. That's information that someone may use in the future. Thanks for sharing.
Welcome to the forum!
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 04-03-2021, 10:35 PM   #4
sjz
UPDATE:
Inside the pop-up support frame tubing there are Torsion bars to relieve the load when cranking up the top. The constant tension at the anchor plates that are lag bolted in place eventually twisted and tore completely through the top. It didn't help that there was no metal reinforcement in there, only wood. I will post some pictures of the repair. You can see the large 2 1/2 inch wide steel angle bracket I had to make for each side. I will post some more pictures of the finished project..
Finished the majority of the project. I plan to re-calk the corners and seams, then clean and re-coat the entire top with fiberglass RV roof coating.
ID:	251131   Click image for larger version
ID:	251132   Click image for larger version
ID:	251133   Click image for larger version
Old 04-03-2021, 10:46 PM   #5
Virginian's Avatar
Nice looking repair! Well done! As stated above, thanks for posting, as it could well help someone else.
2019 Wolf Pup 16FQ - bought new 3/2020
2013 F150 5.0 STX SCab 4x4 SB/3.55 rear/tow pkg./36 gal. tank/1695 Payload/7350 GVWR
Andersen Hitch
Virginian is offline   Reply With Quote
Old 04-04-2021, 07:33 AM   #6
What a great post and a great job!
Thanks for sharing.
Enjoy your efforts and go camping!
Days Camped: '18=51 '19=58 '20=110 '21=94
camper, led, roo, roof, slide
