Slide out seal question on 04 Sunseeker
Hi all,
I have a prob with a water leak on the floor near the exterior corner bathroom closest to the dining area. I checked the slide out floor from outside and inside, and it looks fine. I also don't see any plumbing leaks in the bathroom.
My slide seals look ok, although I am unsure if they are being compressed fully when the slide is in and I cannot see the top seal above the slide well as it is covered by the awning.
My main question is the bottom area of the slide. I see plastic molding there but not really a "seal" like the other three seals. Is there supposed to be a seal on the bottom of the slide too? Should I install one?
Also, there are seals on the inside of the slide around the top and sides too. These do not even come close to touching the slide, whether its in or out. We routinely put blankets on top of the slide (inside) to keep cold air out during the winter. The inside slide areas where these seals are, do not look like they are getting wet. So I don't suspect a leak there although these seals are not doing their jobs obviously.
Any advice on the leak and.or the seals (inside and outside)? I'm going to replace all of them probably, but I still am not certain that the leak I see near the bathroom floor is from a bad seal. I have caulked around the sewer vent pipe on the roof in case water was coming in there. There are no leaks under the bathroom sink. The slide floor is fine as well.
