Old 05-16-2020, 06:56 PM   #1
Camp-N-Nut
camp-n-nut's Avatar
Slide out topper fabric
Where is a good place to buy new slide out topper fabric?
2015 Cedar Creek 34 RLSA
2006 Dodge Laramie Dually Cummins
camp-n-nut is offline   Reply With Quote
Old 05-16-2020, 07:16 PM   #2
Toughtop.com
Great customer service, instructions, and better than OEM material.
Be very careful when measuring and providing measurements. Measure several times. Then measure again. Follow their websites instructions on measuring.
I did both slide toppers last year without an issue but I can understand how someone could mess it up.
If you need to do more than one just order and do 1, learn on the way, and then do the next one separately.
Finding the pin holes to lock the roller tube so you can take the old material off was somehow difficult for me until I interpreted the instructions correctly.
You will need a helper. Getting whacked by an unraveling roller tube with pieces hanging off of it can cause injury or death if you get knocked off the ladder - although if you follow the instructions and have a helper you will be fine.
Chris
2006 Sunseeker 2860DS Ford V10 5 sp. Torq-Flite w Tow/Haul
Winegard T4 In Motion Satellite Dish
Furion Rear Camera, RecPro 70" Recliners
Mohawk Luxury Vinyl Plank Flooring
2013 AWD Acadia Denali, Blue Ox Equipped
ChrisParise is offline   Reply With Quote
Old 05-17-2020, 06:10 AM   #3
Camp-N-Nut
camp-n-nut's Avatar
Tough top is no longer in business. Click image for larger version
Old 05-17-2020, 06:58 AM   #4
007matman's Avatar
This is what I just put on my camper. I have 2 slides.
Solera Universal Slide Topper Replacement Cut-to-Fit Fabric White
https://www.amazon.com/dp/B01N8S43VY..._axsWEbESXZGMJ
It is available in black too.
It is better material than the camper came with originally. For the price of basically one slide I have enough to do both of them twice.
Cutting it is easy.. just use a razor blade and a straight edge. For me, that was a large framing square that I just flipped over after I cut halfway through.
007matman is offline   Reply With Quote
Old 05-17-2020, 07:44 AM   #5
My mistake or they changed their url.
Toughtopawnings,com
A Google search will yield quick results to choose from.
The measurement and installation instructions are probably similar based on your OEM equipment.
Chris
slide, slide out
