Originally Posted by wagraf
Thank you for you insights.
In the piles of brochures that came with the trailer, there are two items that refer to the Dicor PVC Tufflex roofing material.
The holes appear to be the result of installation. They are not tears. Just tiny little holes. I could run it back to Camping World, but I have to wonder if that will be more trouble than it's worth. Just the cost of gasoline will buy the materials I need to do the repair. That is unless you think they need to be aware of this for future reference.
Thanks again for your help.
Well, I learned something today... thanks.
In researching, this is what Dicor (the company) says should be used with Tufflex PVC Roofing...
Lap Sealant (502LS) is a self-leveling caulk used to seal screw-type fasteners and termination
moldings, formulated especially for Tufflex roofing.
NOTE: 551LS Non-Leveling Sealant may be more suitable for use on accessories with taller
flanges such as TV antennas, some skylights, etc.
I found several references to buying it on the internet.
If you believe it was done during manufacturing, you bet I'd be getting it documented... BUT... as far as Camping World... well the consensus isn't good.
