Old 10-15-2019, 11:26 AM   #1
Underbelly plastic shredding
We have a '17 Wildwood 17RB...the plastic that covers the wood floor bottom is coming off as we travel...can it be removed? Should the raw wood be painted or sealed...we have tried to staple it back up and used gorilla tape...not going to last long...any suggestions would be appreciated
Thx
Chevy 2.0 is offline   Reply With Quote
Old 10-15-2019, 11:45 AM   #2
Thx
Could you post a picture? Might help understand what the material you're dealing with looks like.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 10-16-2019, 12:54 PM   #3
If I'm right it looks like black woven tarp material.
If you remove it, you should coat the wood with something. Maybe even spray-on bed liner.
Gotta go campin!
Old 10-16-2019, 01:02 PM   #4
Or roof coating material.
2004 Nissan Titan
Old 10-17-2019, 11:41 AM   #5
Sorry it took so long, some nasty weather last few days....I attached pictures of the issue...I hope you can see what I'm referring to....tx
ID:	217484   Click image for larger version
ID:	217485   Click image for larger version
ID:	217486   Click image for larger version
Old 10-17-2019, 12:16 PM   #6
Find sheets of clorplast and upgrade to an enclosed underbelly
Kimber45 is offline   Reply With Quote
Old 10-17-2019, 01:43 PM   #7
Sealing with bedliner product doesn't sound too bad....or roof coating ... I tried to Google clorplast...nothing came up on that...ok see it is coroplast....plastic sheeting...could also work...thanks all...any other suggestions are welcomed
Old 10-17-2019, 04:06 PM   #8
Stuff is also known as Polypropylene Fluted Sheet
Here's one source for 48"X96" sheets
https://www.interstateplastics.com/P...SABEgKx3PD_BwE
They're showing it in white but a phone call could find out if they also have Black which is std on FR products.
A hint if you plan on covering the underbelly. First install some 1"X2" furring strips between the flanges of the frame so you have more places to secure it and be sure and use LARGE fender Washers so the sheet doesn't pull off the screw heads.
2004 Nissan Titan
Old 10-17-2019, 08:38 PM   #9
Thanks for the information & tip...sounds like a good way to solve this issue... appreciate the help
Old 10-17-2019, 08:55 PM   #10
Retired Old Fart
dward51's Avatar
Home Depot around here stocks the white panels and can order the black. So check with your local big box store. Also it's the same stuff they make yard signs out of (like campaign signs, just cut into smaller squares). Sign shops buy it by the roll so that may be a possible source also.
I do know that Lippert will sell it. A complete roll to redo my 246RKS underbelly was only like $140. They were the least expensive option for me, but they did some warranty work where I had to take the underbelly off and reinstall it so I may have received a break on the price (cost?).
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
underbelly
