Have a 2021 Sabre 37FLH. Have same problem. Developed leak coming from outer wall behind toilet. Found seperation at aluminum trim where meets outer wall. only has two screws attached to trim at outer wall. Checked underneath and behind trim where wall meets floor. Sure enough, chaulking all weathered and washed behind trim. Factory was sealing long portion of trim with caulk. needed more screws!. Two for about 8 feet of trim is not enough! Chaulked with Flex Shot Clear. Factory caulk was very thin and is not for gluing things together. Both sides did the same from the rear, going to the front.
Advised and showed my rep at Camping World, Dover, Florida, yesterday. He smiled and said you have to continously watch for that! Told him to contact the factory and advised them to install and caulk better. TAKE PRIDE IN YOUR WORK!
Bob Stevens
Zephyrhills, Fla
