Old 08-23-2020, 05:45 PM   #1
Weather stripping cracked
Anybody experienced this? 2018 model and everybody instantly says the warranty is expired. Recommendation on DIY replacement parts and any installation advice? Currently living in it full time, so dropping it at the dealer isn't an option. T Y I A!!!
ID:	237460   Click image for larger version
JohnnyB38 is offline   Reply With Quote
Old 08-23-2020, 05:59 PM   #2
Oaklevel's Avatar
Is that the strip that covers the screws??? If so it is not insulation. Very common issue.
Also it is very easy to replace. You buy it by the foot. Just pops in.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-23-2020, 06:06 PM   #3
Re:
-Oaklevel, it's covering the screws. I appreciate the insight!!! Since one side cracked, I'm gonna do both on principle.
Old 08-23-2020, 08:51 PM   #4
Super easy to do and inexpensive. Our new TT had sat on the lot for 16 months. The black trim cover cracked in 3 locations, multiple on each. Didnít notice it until after our first trip during my post trip inspection. Could have tried warranty but $19 for 50í of trim cover (JR brand) shipped to my house (Amazon) and 30 minutes and it was done. Checked all the screws underneath while I was at it. Donít forget to seal the ends when you are done. Choose the sealant of your choice to match what the factory used
2019 RW 2902WS
2019 Ford F-150 CC 4x4 w Max TT
TheMcBees is offline   Reply With Quote
Old 08-24-2020, 11:43 AM   #5
my 2018 20rdse is doing it also
I see people have posted it is an easy fix... ok, what do I search for (what is it called) to buy some replacement material?
If I put the same thing wouldnt it likely crack also? Should I also add any tape or some other sealant?
Bill
USAF Ret
squatch93 is offline   Reply With Quote
Old 08-24-2020, 01:25 PM   #6
This is what I bought. Camco also makes it. This seemed to be a bit thicker.
Old 08-24-2020, 11:23 PM   #7
dbledan's Avatar
Search for "vinyl insert screw cover" or the premium version posted above.
I went with lower end stuff and not sure it will last very long but at $19 for 100ft and about 10min work I can replace it again next year with the higher end next year.
dbledan is offline   Reply With Quote
crack
