03-10-2021, 08:48 PM
What do you do when a screw is loose?
Hi,
I took out the outside bracket of the shower and when I try to put it back in I notice two of the screw cannot screw in tight. it just keep on turning. Anything to add to it so I can make it tight again?
thank you
2021 Geo Pro 20BHS
2020 Tacoma TRD SPORT 4x4
03-10-2021, 09:11 PM
Sometimes you can put some wood glue in the hole then tap 2 or 3 toothpicks into the hole, cut them off flush with the surface and then put the screw back in. It depends on what material you are screwing into because if it is a thin panel or fiberglass sheet this won’t work but a thin panel or sheet shouldn’t have screws in it in the first place.
When I read the thread title my first thought was “I have had a screw loose for years and it just adds to the fun I have”.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
03-10-2021, 09:12 PM
Originally Posted by aboyz
Hi,
thank you
Click on the # 6 and see what you think about this idea.
03-10-2021, 09:44 PM
thank you.. this is one method to try. I'll try that and see how it goes. This is the screw on the outside of the trailer. I think its a fiberglass sheet. Do they make anything like for drywall at home where you put in that plastic stuff and screw in the screw?
Something like that for the trailer? or it will not work?
2021 Geo Pro 20BHS
03-11-2021, 01:37 PM
You may need a larger diameter screw.
03-11-2021, 01:42 PM
My first thought just reading the title was.... "Tighten it...."
03-11-2021, 01:46 PM
toothpicks work for me.
03-11-2021, 01:51 PM
I am thinking there might be a nut with little flanges that allow it to grip the inside wall keeping it from spinning... in that case, once you get the bolt in the nut head, use a flat head screw driver to apply some outward pressure on the bolt forcing the flanged nut head to grip onto the wall while also spinning the bolt into the nut... sounds more complicated then actually doing it.
YOUR Original post says you are tightening a screw ( tapered), but is it actually a bolt ( no taper)? Then what I wrote might work... otherwise forget it if it is actually a screw-head.
2014 Shamrock 183
03-11-2021, 02:01 PM
The toothpick trick works well when going into wood, but in plastic or fiberglass-not so much, There are a variety of drywall screw anchors that would better fit the bill. They are also weather resistant.
https://www.amazon.com/s?k=drywall+s...27&ref=sr_pg_1
03-11-2021, 02:40 PM
My DW has said I’ve had a screw loose for years, I just go have another beer! LOL
03-11-2021, 03:08 PM
Just as confused as you
How many beers does it take to disguise the wobble caused by a loose screw?
My DW says I'm nuts, the bolts have been missing for as long as we've known each other.
Richard & Jill
03-11-2021, 03:25 PM
Go see a psychiatrist.
I'm sorry - I could not resist.
03-11-2021, 03:36 PM
Boss Ox & Drovergirl
I would suggest 2 part epoxy to fill the hole, then after it's cured, drill a pilot hole for the screw, then hand tighten.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
03-11-2021, 04:06 PM
It is not uncommon for someone to overtighten a sheet metal type screw and strip out the hole. What most people do, in my experience, is replace the screw with one one size larger and don't over tighten. You could also coat the screw with a sealer to prevent leaking.
03-11-2021, 05:21 PM
Or seek psychiatric help
03-11-2021, 05:30 PM
Why, much more fun this way!
2022 Rockwood 2893BS
2019 Ram 2500 Longhorn CTD
03-11-2021, 06:07 PM
Hi,
thank you
Two steps:
1) Get larger screws. If your screw is a #10, step up to a #12...same length.
2) Before installing the screw, add Gorilla Glue. Snug up the screw but don't over-tighten. Get the minis. They last longer than a larger quantity that can dry out after opening: https://smile.amazon.com/Gorilla-Cle...5503924&sr=8-1
The Gorilla Glue acts like LocTite on nuts and bolts. It secures the screw in place, but you can remove it with an impact drill driver or determined effort with a standard screwdriver.
ALSO. Always use stainless steel screws...everywhere in the camper. They don't rust; they are compatible with aluminum; they can be painted.
If you need, say, a black screw, get a can of Rustoleum or similar paint. Screw the screw partway into a cardboard box or similar. Spray paint the screw and give it overnight to dry...so the paint can harden. Then install.
I carry a small divided parts box packed with all different sizes of screws, nuts (nylock), bolts, washers, and other stuff. All stainless. A fix is quick and easy.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
03-11-2021, 06:38 PM
Hi,
thank you
stick a tooth pick in it
03-11-2021, 06:41 PM
Hi,
thank you
these are great for fixing holes in wood or metal
https://www.google.com/aclk?sa=L&ai=...gQIEBBC&adurl=
03-11-2021, 07:23 PM
I use wood matchsticks.
2016 Nike Take Down Wrestling Shoes
42 ft square Dollamur high school wrestling mat
