Old 04-13-2024, 06:39 PM   #1
Question What is this bracket for?
What is this Bracket for? 2020 Flagstaff Mico Lite 21DS. Click image for larger version
It is about 2 Ft aft of the door. Directly under the kitchen windows. Picture 2 shows it framed by the grab bar.
Ted.Clemens is offline   Reply With Quote
Old 04-13-2024, 06:40 PM   #2
Pictures are rotated 90 degrees off.
Old 04-13-2024, 06:44 PM   #3
bikendan's Avatar
Originally Posted by Ted.Clemens View Post
What is this Bracket for? 2020 Flagstaff Mico Lite 21DS. Attachment 298667
Attachment 298668
Moving the inside tv to the outside. That's why the connections are below it.
Old 04-13-2024, 06:44 PM   #4
Mr. Dan's Avatar
It appears to be a mounting bracket to hang your tv outside.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78/'24 = 41; Booked for 2024 = 55
Old 04-13-2024, 06:44 PM   #5
Ahhhh. Thank you
Old 04-13-2024, 06:46 PM   #6
Television
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 04-13-2024, 07:00 PM   #7
Looks like the mods win this contest. 100% of the answers are from them.
Larry
Larry-NC is online now   Reply With Quote
Old 04-13-2024, 07:19 PM   #8
It's called a "paw mount", if it matters, you can either move your inside TV outside or buy an extra of the male side and install it on a spare TV.
As a side note, on our 2020 model 21DS, it is very difficult to lift the TV high enough to get it to disengage from the paw mount on the wall bracket. it's really a pain. I had to extend the wall mount fully and turn the TV a few degrees left or right to get enough clearance.
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is online now   Reply With Quote
Old 04-13-2024, 07:46 PM   #9
bikendan's Avatar
Actually it is probably NOT a PAW mount. I have the same mount on my TracerAir TT and PAW mounts don't work with the FR V-mounts. Not sure who FR sources their V-mounts from but it's not PAW.
I know this because I needed a V-mount for the bedroom tv arm so I ordered one from PAW. Didn't fit so I called them and was told that FR uses a different mount and theirs won't work.
Old 04-13-2024, 09:42 PM   #10
FR probably gets them from who ever has them available. My 2022 has PAW mounts. But when I wanted another PAW was out and wanted $39 for a male and female pair.
I ordered from Walmart with the TV and got another brand for $10. looks the same but not PAW brand. DR
dangerranger is offline   Reply With Quote
Old 04-13-2024, 10:54 PM   #11
Mr. Dan's Avatar
… except for 5picker’s.
Old 04-14-2024, 07:37 AM   #12
Mookie58's Avatar
You should have received the corresponding square male bracket meant to attach to another TV in your accessories bag in the camper. Our Micro Lite has the same outdoor bracket. I know I'll never use it. If I'm outdoors I'm watching the outdoors, not TV.
2024 Flagstaff Micro Lite 21FBRS
2021 RAM 1500 Bighorn 5.7L Hemi
Take the high road. It's usually less muddy.
Mookie58 is offline   Reply With Quote
Old 04-14-2024, 07:46 AM   #13
This is what I bought for my extra television mount. Metal not plastic. It is mounted so I can just drop the television down so I am not looking up.
The link gives the dimensions of it also.
https://www.ebay.com/itm/163065175259
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab 4x4
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 04-14-2024, 03:20 PM   #14
bikendan's Avatar
Yep, PAW mounts are plastic while the one pictured is metal as is the corresponding mount.
Old 04-14-2024, 03:39 PM   #15
Except for the steel ones.
https://www.pawinternational.com/pro...39459325706486
2022 Rockwood 2511S
Old 04-14-2024, 04:05 PM   #16
bikendan's Avatar
They didn't have steel ones, back when I was in communication with the owner of PAW International.
So does this plate accept the plastic PAW tv mount?
Old 04-14-2024, 05:18 PM   #17
No. The dimensions are different. Not sure where I got the plastic dimensions but got the steel dimensions on the ebay ad.
2022 Rockwood 2511S
Old 04-14-2024, 07:17 PM   #18
bikendan's Avatar
So does PAW have the Vmount that slides into that steel mount?
Old 04-15-2024, 05:45 AM   #19
Up to the buyer to determine dimensions,buy the set.
https://www.pawinternational.com/pro...42183007437046
2022 Rockwood 2511S
Old 04-15-2024, 11:16 AM   #20
bikendan's Avatar
That's exactly what my TracerAir TT had.
bracket
