Old 07-11-2020, 01:23 PM   #1
What kind of seal is this on my trailer ladder?
I want to replace the seals around the ladder on my 2018 Flagstaff Micro Lite 21DS, but I can't figure out what kind of seal they used around the ladder feet. Anyone ever seen or replaced seals like this?
https://ibb.co/hRknhSy
exploresomemore is offline   Reply With Quote
Old 07-11-2020, 02:50 PM   #2
Flybob's Avatar
Bedding compound or bedding tape.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-11-2020, 02:59 PM   #3
bubbles's Avatar
Butyl tape.
Old 07-11-2020, 05:35 PM   #4
Originally Posted by bubbles View Post
Butyl tape.
Hate the stuff personally. Seems like it's the number one cause of black streaks, at least to me.
If I were to re-do the ladder attachment points I'd probably just use something like Dicor or Alpha sealant for vertical surfaces. Just enough under each pad and tool off whatever is squished out just like when bedding deck fittings on a boat.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-12-2020, 06:44 AM   #5
Thanks for the replies! I think I'll try a dicor sealant for vertical applications since I've worked with those products before and they seem to last longer than whatever this rubbery seal is.
Old 07-12-2020, 12:53 PM   #6
BillyBass's Avatar
Being only two yrs old they shouldnt be bad already.
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 07-12-2020, 02:54 PM   #7
mike.t's Avatar
Looks like some square pad they had lying around that they chewed the corners off.
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
2012 Dodge Challenger
I was never taught not to like you, you did that!
mike.t is offline   Reply With Quote
Old 07-12-2020, 03:52 PM   #8
Can you run 3800 fps?
That's why I used WHITE tape...
SniperDroid is online now   Reply With Quote
Old 07-12-2020, 07:39 PM   #9
You'd think so, but some of the feet don't have any of this padding show anymore. They might be fine under the screws, but it looks really dry and cracked everywhere.
Old 07-12-2020, 07:46 PM   #10
TowPro's Avatar
as long as its ozzing out like that, its still sealing.
its OK to clean up those edges. its only putty
2019 Forest River Forester MBS 2401R
TowPro is online now   Reply With Quote
Old 07-12-2020, 07:54 PM   #11
007matman's Avatar
Clean up the edges and call it good. That's what the stuff is supposed to do. It's in there to keep water out.
Sometimes you can run a bead of sealant like Pro-Flex. However, sometimes it'll even work its way out of that.
007matman is offline   Reply With Quote
Old 07-13-2020, 09:43 AM   #12
Wolverine 1945's Avatar
Right On !!!
It is much like Plumbers Putty !!!
Wolverine 1945 is offline   Reply With Quote
seal, trailer
