Old 05-20-2017, 07:09 PM   #1
TN_Cruise_Lite's Avatar
Question 195BH Add a Room installation-need advice
Been considering an Add a Room for a while. I looked at all my options and chose Shade Pro. Couldn't be happier with my decision, they sell a quality product with unbelievable customer service. UPS damaged my rafters during shipment and Shade Pro sent new ones asap. Here's what I chose:
https://www.shadepro.net/product/limited-add-a-room/
I do have an issue with the install and I'm looking for ideas. As luck would have it where I have to install a bracket there is no wall stud, only the header. As you can see from the attached pic the upper screws are securely into wood. The lower holes have no screws because there's nothing behind them. The marks near the brackets are not scratches, they wiped right off. Any ideas on how to deal with this issue?
In this pic you can see the offending bracket circled in green. It also shows the horizontal rafters and vertical snapless poles installed.
2018 Coleman Light 1805RB
2010 Chevy Silverado 4x4
2013 Salem Cruise Lite 195BH (traded)
TN_Cruise_Lite is offline   Reply With Quote
Old 05-21-2017, 03:08 PM   #2
Decided to pull the wall panel and no damage done other than the cut in the seam tape. Pleasantly surprised at how well the wall is constructed. Looks like a 45* wooden block glued and screwed in the corner should work.
Old 05-22-2017, 06:44 PM   #3
My solution
2"x10" glued with Titebond and screwed
Like it never happened
roo
