Old 09-07-2021, 11:07 AM   #1
366RL Entry door stuck closed
Help!! My entry door is stuck, and I can't get in to my camper. I have a 2021 Columbus 1492 366RL, and I cannot open the entry door to get inside. The handle pulls out, but the door won't open.
This is very frustrating. The camper is useless if I can't get in it.
I am not set up. It is actually still hitched to my truck. I just returned from a weekend of camping. I wanted to unload it at my house before taking it to storage.
Please help. I have trouble opening the door when it is setup. I was told that is because of the great weather seal around the door. I had to learn how to open it.
HELP!!!
Sweet Tea is offline   Reply With Quote
Old 10-31-2021, 09:28 AM   #2
I eventually got it to open. I am not sure what was different when it opened other me praying about it.
Old 11-01-2021, 07:43 AM   #3
SeaDog's Avatar
doors can stick if the rig is not somewhat level if it happens again check the level of the rig and see if that is the problem. (frame twisting and flexing)
Retired Navy
2016 Flagstaff 26 FKWS
Old 11-01-2021, 08:07 AM   #4
llr
It could be similar to the issues on my Grand Design. I had to remove the strike plate and flatten it out and grind the tops off the round head screws they used. This made it ok, but the proper fix would be to pull the door out and make the opening about 1/16" wider. Haven't decided if i will do that yet.
I highly doubt if it is the weather seal and it should open properly not leveled at all or properly leveled.
The 1st step is finding the issue. I used painters tape where I thought the issue was. When you find it the tears in the tape will be obvious.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
llr is online now   Reply With Quote
door
