Old 05-23-2022, 12:39 AM   #1
9200 awning motor
Im having some issues with my 9200 dometic motor…. A new one is more than 550$ and it coűd be worse.
Does someone already find a good solution to fix that motor like buying another part to replace only the motor, not the gear?!?
Spartan81 is offline   Reply With Quote
Old 05-23-2022, 12:01 PM   #2
You could try to contact the manufacturer or check with the dealer to see if they can get you a replacement motor.
Welcome to the forum.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-23-2022, 10:08 PM   #3
Thank you!
But i would like to know if someone already switch only the motor part by,for example, a easy to get, low cost, universal awning motor that we find at Amazon
Old 05-23-2022, 11:01 PM   #4
What type of issues are you having?
Why pay anything for a part that "may" not fix your problem. It's always best to diagnose rather that throw parts at something.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=90
Old 05-23-2022, 11:13 PM   #5
Awning is now really really slow, each time îm wondering if it’s going to make it. Rv dealer told me it was the motor! Damm my rv is 2 year old,
Old 05-23-2022, 11:47 PM   #6
I don't recall where and haven't looked, but I recall some correspondence about the motor being the same as a standard car window motor. Apparently, those are common and cheap and can be adapted as you describe, but I have no further information to offer.
TV: 2016 Ford F-150 SCrew EB RWD Lariat MaxTow
RV: 2020 Rockwood Mini-Lite 2507S
chriscowles is offline   Reply With Quote
Old 05-24-2022, 09:10 AM   #7
Well... it "could" be the motor as someone told you... but... without checking voltages and hardware for binding, replacing the motor is nothing but a guess.
My point... unless you are 100% certain it is the motor, ANY money you spend replacing it could be wasted if the cause turns out to be something else.
Old 05-24-2022, 01:33 PM   #8
Everything have been check! Voltage, gear and all that stuff. My point is knowing that, could i replace just the bottom part of the dometic 9200 part (witch is the motor) by, for example, that motor: Dorman Moteur lčve-vitre noir 742-141 https://www.amazon.ca/dp/B001KQ43SS/...ing=UTF8&psc=1
awning, motor
