Old 02-03-2024, 11:46 AM   #1
actuator/solenoid replacement in door
I have a 2019 Dynamax DX3 and the fuse for the keyless entry blew. First from dynamax it was the wrong size (5A instead of 15A). Then when I replaced it with a 15A, it blew again. So I read it could be the actuator. When taking the handle off the door, I find that the actuator is buried inside the door construction. Is there an easier way to get to it then taking apart the entire door? TIA
Chip
chipaileen is offline   Reply With Quote
door, replacement
