Old 07-17-2023, 10:28 PM   #1
awning edge issues
I have a 2021 Shasta 31OK. One side of the awning edge is coming apart in two pieces at the 12" piece that hangs down and up one of the edges side. Has anyone used awning tape to seal it shut, any other recommendation to fix, or is it time for a new one, because I don't think the extended warranty covers it?
Thank you for any help and replies in advance,
Jeremy
Jeremy R is offline   Reply With Quote
Old 07-18-2023, 12:13 AM   #2
bikendan's Avatar
Pics are often more helpful than descriptions.
Sent from my SM-G781U using Forest River Forums mobile app
Old 07-18-2023, 12:04 PM   #3
Added images
Jeremy
Added images
ID:	290415   Click image for larger version
ID:	290416   Click image for larger version
ID:	290417   Click image for larger version
ID:	290418   Click image for larger version
Old 07-18-2023, 12:06 PM   #4
Thank you for your reply and suggestion. I am a visual person, so I should have done that with my initial post. I have uploaded some pictures.
Old 07-18-2023, 12:10 PM   #5
go to shadepro.com give them the length of awning and brand and order new fabric .for a 12' awning should only be about $150 . they have better material and replacement is not to hard .
MR.M is offline   Reply With Quote
Old 07-18-2023, 12:30 PM   #6
I agree. Time for a replacement.
Bob
Bob K4TAX is offline   Reply With Quote
Old 07-18-2023, 02:03 PM   #7
rsdata's Avatar
Gorilla tape either the original or the new clear tape... maybe it will get gummy in hot sun though...
2014 Shamrock 183
Old 07-18-2023, 02:21 PM   #8
Wow! That's in bad shape for a 2021.
Had you ever cleaned and/or used protectant on it?
If so and it deteriorated like that, I'd be contacting the manufacturer.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
Old 07-18-2023, 02:31 PM   #9
I clean it with the awning cleaner a couple of times a year. I could not get it all the way cleaned though. I believe I kept it rolled up the incorrect direction as it is reversible.
Thank you,
Jeremy
Old 07-18-2023, 02:42 PM   #10
Thank you!!!!
awning
