Originally Posted by Mandog
Yep my motor runs fine but awning won’t retract: Can’t find a new one anywhere: called Dometic and they said they have no idea when they’ll be available. I’m changing to manual set up. Absolutely hate Dometic for this and will never recommend them for anything again. Building junk and they don’t care.
Bump...thinking about your awning motor fault.
A solution could be to remove the worm driven gear, see if the plastic gear will pull off, or press off, drill the shaft for a small roll pin then using a dremel, mill two matching slots into the gear and reassemble.
This assumes that the bond between the the gear and shaft is at fault. And the gear isn't destroyed. And not under warranty.
The above can be implemented without removing the motor, or roll tube end cap. Remove the planetary gearbox cap screws, the motor and gearbox will separate, and the shaft/gear assembly will pull out without issue. No further disassembly required. The sun and planet gears will remain in place behind an easily removed cover. I'd pull that out too and check for lube. The main planetary output shaft will not pull out without drilling out the roll tube endcap rivets and unlocking the shaft clip. Mitor replacement requires drilling out the rivets and removing the end cap. The OEM rivets are stainless steel. I used aluminum rivets due to still having to replace the roller and fabric when it (if?) becomes available. I'll finish with SS once completed.
The motor output shaft and the left support requires an occasional squirt of silicone lube. I use slide lube.
The only other issue would be if the worm drive gear teeth are screwed. But you said that you were able to roll it up by hand and that would not be possible if only a few worm teeth were missing.
Be sure and have support for the roll tube while you do this. Easier if the awning is extended. The tube is not heavy. I use a drilled 2x4 and strap to support mine when apart.
Bought a motor for $200 bucks off ebay. Works perfectly. It occurs to me that the most stressful motor activity might be jamming the roll tightly against the rail when retracting. I'm snugging, but stopping before it bogs the motor. It has plenty torque to extend and retract without bogging down.
Another issue could relate to heating the motor and drive with repeated adjustment...?
Dometic has a specific standard for where to stop when extending.
Still waiting on a return call regarding my brand new, but failed motor. I'm guessing the new bracket assembly motor that was bad out of the box might have been swapped out during the two months that the bracket assembly was sitting in the dealer's warehouse? They knew that the roller and fabric was on perpetual b/o. Just a guess...? Going on 4 months now since original order.
Now I'm in direct contact with Dometic re our 300 recalled pottie. Apparently they have replacements in house.. we shall see....
Apologies for the epistle.
