Old 03-21-2018, 10:08 AM   #21
rracer5's Avatar
Originally Posted by youroo View Post
On the Smooth Side units with Elect Awning that have Vertical Extruded Channels riveted Tight against the Smooth walls,how/where do you install this Velcro or Wire Ties you speak of to hold the Arms? Youroo!!
On most, there should be a small gap where they put sealant behind the channel before bolting it to the side. In my case, I was able to "sneak" a piece of velcro behind and wrap around the arm to hold it against the channel.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 03-21-2018, 10:14 AM   #22
rracer5's Avatar
Awww...jeez
2014 Sanibel 3250
Old 03-25-2018, 07:24 PM   #23
Awning fell off on highway.
I had the same thing happened where my awning came off on the highway. The problem with my awning was is a pin came out where it's connected to the motor. Forest River Center was an act of God. The pictures that were taking and shown to Forest River showed that the pin holding the Motor Inn came out. The awning that I had those Dometic.
Chillyman3 is offline   Reply With Quote
awning
