Old 09-16-2019, 07:32 PM   #1
Awning LED Lights Wiring
Does anyone know how the power cable for the awning led lights is routed on a 2017 Sierra 393RL Coach? I am trying to run down and troubleshoot a problem with the cable that supplies power from the control panel switch inside my Coach to the lights. There is an apparent “bad” connection, for lack of another word in the cable and I’m getting only 6.9 vdc at the terminals of the molded connector that supply power from the switch to the lights. I see the power cable from the switch routed up through the ceiling. Used a borescope camera to view it but did not have any luck. I also noticed that the wires at molded connector end of the power cable run inside the bedroom wall from outside and go down toward the frame. I pulled drawers from a dresser at this location, saw wires but not the ones from the LED light connector. Any help would be greatly appreciated. Thanks!
snoopyf150 is offline   Reply With Quote
awning, led, light, wiring
