Old 05-27-2013, 10:08 PM   #1
Awning not retracting straight
My awning is not rolling on straight. Once it is up it is wrinkled and one end is not firm against the TT. How do I fix this? Is it just to pull on the awning where it connects to the TT to adjust side to side?
2016 Siverback 33IK, Towed 30K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
dalford is online now   Reply With Quote
Old 05-27-2013, 10:11 PM   #2
Deploy the awning and center it on the tube and then pop rivet it in place.
Old 05-27-2013, 10:18 PM   #3
Old Coot, so I should adjust it at the tube and not at the rail on the top of the trailer? Rivet in place, great idea, thanks..
Old 05-27-2013, 10:21 PM   #4
The awning should be already centered at the trailer between the uprights and a screw in each end. All you need to do is to center it on the tube when it is deployed and rivet it in place.
Old 05-28-2013, 08:24 AM   #5
lindy's Avatar
Roll the awning up and watch which way the fabric travels, left or right as it rolls up and then slide the fabric in the roller until when rolled up the fabric does not walk left or right. The fabric might not end up being centered on the roller, but make sure it stays aligned while rolling up then rivet it to the roller.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
