After seeing the initial post about billowing at 60 MPH and reading about a pile of bent and twisted awnings after the Mackinaw bridge, I contacted Lippert because my trailer used Solera from Lippert for both the slide topper and 20' wide awning. I find it amazing they replied with the following with no model numbers, only that it was a new Apex trailer.
So word of caution - I don't know if these parts will fit, but I will find out.
EmailToCase <customerservice@lci1.com>
To:
Mon, Aug 23 at 1:15 PM
Hi David,
Thanks for reaching out to Lippert.
Absolutely, we have and travel lock for a Solera patio awning, and an anti billow device for Solera slide toppers.
The travel lock would require each of the following parts in the quantity listed to the left:
1 - WIRE BAIL LATCH WITH CATCH 233984
1 - SPACER, BLOCK 289428
2 - NUT - #6 - 32 HEX NYLON INSERT 272458
2 - SCREW - #6 296414
2 - RIVET - 1/8" X .337; SST/SST 255902
The anti-billow device for the slide toppers is
728810 ANTI-BILLOW - SLIDE TOPPER - KIT; BLACK
728811 ANTI-BILLOW - SLIDE TOPPER - KIT; WHITE
You can order these here:
https://store.lci1.com/quickorder/ or by calling us at 432-Lippert.
Thank you much!
Logan Williams
Contact Center Parts Representative
w: 574.537.8900 | f: 574.534.7161
