Old 01-19-2022, 02:23 PM   #1
Awning probs
Hello folks
Wondering if anybody has run into awnings won’t roll out , rig is 8/9 year old forest river “Georgetown “ , hear a click when switch is operated out at roller?? Beyond that we get nothing, just replaced both batteries
Thanks in advance
AkitaCoach is offline   Reply With Quote
Old 01-19-2022, 02:41 PM   #2
sdelam's Avatar
Had an issue with mine last year. I used a impact driver/drill to open it a few turns and that seemed to fix it. Worked normally the rest of the season. I guess i will see if it needs a jump start this spring.
2020 GMC Denali 4X4 2500HD Duramax
2018 Work & Play 25WAB
sdelam is offline   Reply With Quote
Old 01-19-2022, 03:42 PM   #3
rracer5's Avatar
Originally Posted by AkitaCoach View Post
Hello folks
Thanks in advance
What model awning is it?? If it's a Dometic 9200 with the linear style motor in the end of the roller, it could be seized. When I had the same sound from mine, I had to replace the motor.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-19-2022, 03:44 PM   #4
Dometic 895 model #
Dometic 895 model #
Anybody know how to manually extend or retract these, I did a bit of searching but am not finding info on manually operating as it is a CV power awning? Thanks
Old 01-19-2022, 04:41 PM   #5
Just a note of information... (I see you have 3 posts)
Forum members using the mobile app DO NOT see individual post titles.
Your information of your awning being a Dometic 895 would not be seen by anyone using the app since that info was in the post title. It is always best to put as much information in the body of the post as possible.
Have you checked for power through the switch and at the awning with a multimeter? Knowing whether you have voltage at the proper components is the first step in diagnosing.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=88
Old 01-19-2022, 04:57 PM   #6
I added the info to the post.
Iwritecode is offline   Reply With Quote
awning
