If the awning is rubbing on the top of the slide frame, maybe you can put pool noodles or even pipe insulation on the corners to prevent chafing? You’d obviously need a ladder to put it up there. That configuration is OK when the slideout isn’t too deep but IMO a full 3-4’ deep slide is too big to put under an awning. On our Rockwood Signature, the door side (living room) slideout has an awning mounted on the face of the slideout. The down side is that there’s a space between the awnings. I had the dealer install a topper on the that slideout and when you extend the main awning it just slightly touches the roller for the topper.
