Old 08-08-2011, 09:24 AM   #1
BigDTx's Avatar
Awning Replacement, 12V or manual
We are ready to replace our awning and I am wanting to know who has a power awning and do you like it? Would you get a power awning again or go back to manual? I am looking at the Carefree 12V awnings, we have a A&E Sunchaser now but the arms are tweaked (from previous owner) and it is very difficult to stow or extend with the bad hardware, also our material is now torn.
any recomendations on 12V power awnings or really easy to use manual? I wuold like to have one that the DW can setup or take down. Ours is 21ft and requires two people to set it up. I like that the Carefree uses a crank handle to extend/retract, A&E doesw not have that option.
Thanks for any help!
BigDTx is offline   Reply With Quote
Old 08-08-2011, 10:44 AM   #2
Triguy's Avatar
Love our power awning. It came with our trailer and is made by Dometic, I believe.
Easy to extend and retract, strong arms and the arms are out of the way when extended.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-08-2011, 10:51 AM   #3
BigDTx's Avatar
do you have a model# or model name?
Old 08-08-2011, 10:53 AM   #4
Location: Canandaigua,New York (The heart of the Finger Lakes)
Power....only way to go !!!
David & Annamarie & 2-Pugs (Fatty and Harley)
2011 Rockwood Windjammer 3065
2011 Ford F-250 6.2- V8
2011 Hensley Arrow "NO-SWAY" Hitch
BigRed is offline   Reply With Quote
Old 08-08-2011, 10:58 AM   #5
BigDTx's Avatar
what brand and model do you have?
Old 08-08-2011, 11:01 AM   #6
Old trailer had a manual. New one has an electric. The electric one goes up or down with just a push of a button, so its something my wife can handle. Since I'm lo-tech, worry about problems down the road, and how much it shortens battery life dry camping. Wayne
wayne anthony is offline   Reply With Quote
Old 08-08-2011, 11:15 AM   #7
BigDTx's Avatar
can anyone reccomend a specific model/manufacturer that you have had good luck with, is one brand better than another?
Old 08-08-2011, 11:32 AM   #8
Triguy's Avatar
I'll check when I get home from work, Dan.
Scott
2012 Shamrock 233S
Old 08-08-2011, 11:59 AM   #9
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Well, if you like to visit the beach or other windy places, I think you will quickly find out that you can't tie down an electric awning or put awning de-flappers on it. At least as far as I know.
dimurrrw is offline   Reply With Quote
Old 08-08-2011, 12:49 PM   #10
miatared's Avatar
FYI
Dometic and A&E are the same company.
I do not know of any other company that do awnings, but even if there are other makers, I would stick with A&E - parts and service will be better.
Denis & Diane
* Happy Campers *
miatared is offline   Reply With Quote
Old 08-08-2011, 01:00 PM   #11
BigDTx's Avatar
Originally Posted by miatared View Post
FYI
A&E Dometic and Carefree of Colorado are the only ones I am looking at. Thanks for the help.
Old 08-08-2011, 01:40 PM   #12
flc
flc's Avatar
I'm really not one to like "gizmos" but , so far, I really like the power awning that came on my 2011 Flagstaff. I use it much more than I ever did my manual because it's so easy. I push a button and put it up when we drive off or go to bed. Wind can be a problem in this part of the country so I never left my awning down, tied, anchored or whatever.
2013 Bullet 248 RKS (soon)
2012 F150 SuperCrew w/Ecoboost 3.5L
flc is offline   Reply With Quote
Old 08-08-2011, 01:42 PM   #13
BigDTx's Avatar
do you know what brand and model it is? Thanks
Old 08-08-2011, 07:22 PM   #14
TURBS's Avatar
i have a 9100 series dometic power awning ! love it
www.dometic.com
Old 08-08-2011, 08:32 PM   #15
AKA Bluebird
dimurrrw's Avatar
When the day comes that a power awning can take the same stresses as a manual awning (when tied down, etc,) I will gladly get one. My two cents!
Old 08-08-2011, 08:50 PM   #16
TURBS's Avatar
i understand your opinion but heres my take ..... if you will.
manual awning.
undo retainer clips
release swing out lever
find awning puller
try 3 times to hook strap
pull down awning 1 foot
manually pull out arm thats stuck
pull awning all the way down
slide arms up and tighten knobs
ones stripped
raise awning one side at a time
oppps forgot awning savers
both arms back down
install savers
grab ropes opps forgot to attach them
pull arms back down
attach ropes
pull arms back up
grab twisty dog /awning stakes
screw into ground
attach ropes
reverse procedure to put awning away
electric awning
hold button 15 seconds .
done
i hope you can smile at this comment
Old 08-09-2011, 06:02 AM   #17
AKA Bluebird
dimurrrw's Avatar
Old 08-09-2011, 07:14 AM   #18
zaih05's Avatar
Hello, I'm the guy that's new to all this and through his own stupidity managed to down an awning on the first time out. (see separate post)
I had a 2007 version of the Dometic Sunchaser manual. Was easy to use and easy to put up, neglected to put it down, but easy enough to put up.
After a little bit of time on the web and a call to Dometic to try to find out the difference between a few of their models, ended up buying what they now call the "8500" manual. Keeping in mind this awing is something like 72 hours old, we are both pleased with the fit, finish and appearance of the new hardware. Seems Dometic has redesigned the side struts compared to my 2007 model. The new ones hug he side of the unit and have a great appearance.
I was a little surprised to find out different models within the Dometic line had very different mouning methods and different awning header track (is that what it's called?). In the spirit of staying with the idea that fewer penetrations in the shell is best, I went with the one that seemed to be the current version of what I had.
Regardless of what you decide on, I think you'll find that hardware has improved since the manufacture of the one you have now and "manual" awnings do not equate to he trip to the gym for a 30 minute workout they used to! :-)
Good luck and tilt or retract when you are away for even a minute! :-)
John (the unpaid kennel help) & crew
2008 Surveyor SV-303
2010 Chevy Express 2500 Explorer Conversion
zaih05 is offline   Reply With Quote
Old 08-09-2011, 07:30 AM   #19
maxwell18's Avatar
Power awning with the rain drop arms
maxwell18 is offline   Reply With Quote
Old 08-09-2011, 07:58 AM   #20
Wanna Be Camper
SaskCampers's Avatar
Products - Dometic
This one came on our unit and it is quite nice. My SIL and hubby's K-Z unit has the carefree Eclipse unit. Both are nice but IMO the Carefree seems to be a bit sturdier. Our Edgewater had a Dometic manual awning and I will never go back to a manual awning siply for the speed you can retract the power ones when a storm blows in and it is just nice to push a button at bed time and when leaving the CG. VS screwing around with a rod to flip the switch on the roll and then hold the awning while retracting it so it goes back gently.
http://www.carefreeofcolorado.com/ca...&categoryid=36
John & Deb
2011 Flagstaff V-Lite 30WRLS
12 volt, awning
