Old 10-11-2017, 05:58 PM   #1
Awning rolls up dry, comes out wet
Hi. I have a Dometic 19' electric awning on my 2015 Coachmen Catalina TT. I roll it up when it is completely dry and when I unroll it after it has rained, even a week after it has rained, it comes out dripping with water. Anyone have any insight into this?? Thanks, Jeff
jdplawman is offline   Reply With Quote
Old 10-11-2017, 06:01 PM   #2
Flybob's Avatar
Water can enter the ends and wick for a distance. Also make sure you are rolling it up correctly. It is very easy to roll up backward as the motor will just keep running once it is extended until it rolls up in the opposite direction. I have watched people do this. Also occasionally the stitches in the bolt area will pull and open the needle holes allowing water to run into the rolled up awning. You can try seam sealer if that is happening.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-11-2017, 06:52 PM   #3
bikendan's Avatar
Yep, awnings always will wick moisture, especially if it rains.
The only owners with dry awnings, live in the desert.
Old 10-11-2017, 06:55 PM   #4
100%Correct! Youroo! !
Old 10-11-2017, 07:07 PM   #5
Check how it is rolled up, as mentioned above. When rolled in the fabric should be on top of roll, not under it.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is online now   Reply With Quote
Old 10-11-2017, 07:21 PM   #6
Kasual Kamper
I believe that in addition to wicking moisture from rain, condensation forms on the inside from humidity and the sun beating on it.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 10-11-2017, 08:26 PM   #7
It was awesome, had not been camping 4 weeks, the last 3 had been the hottest all summer. Went to roll it out figuring it must be dry with no rain and 80 to 90 every day all day for 3 weeks. Out it cam and rained on my head. Go figure. It did dry out fast when open. But it dripped all over the table, chairs and bikes when I opened it.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 10-12-2017, 12:22 PM   #8
I have the same problem. Open it up to dry whenever you can.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 10-12-2017, 12:44 PM   #9
Semperfi24's Avatar
I had the same issue on my previous trailer, and my issue had nothing to do with water getting in the ends of the awning. Our issue was that where the awning meets the roof, wasn't properly installed, allowing water to get in. We eventually realized that was the issue when we saw it drip water, one drop at a time when the awning was extended and it was raining. So make sure to check that possibility as well.
_________________________
2019 Ford F250 Lariat 6.7 Powerstroke
2020 Cherokee Arctic Wolf 287BH
Semperfi24 is offline   Reply With Quote
Old 10-12-2017, 01:21 PM   #10
Kasual Kamper
I'm wondering if covering the roller with something while it is closed, such as a length of drainage pipe, would make a difference.
Old 10-12-2017, 01:52 PM   #11
Bikersarge's Avatar
When we are not using ours I extend the awning about once a week to dry it out otherwise you end up with black mold.
Not Camping enough Need therapy
2013 Forest River Salem/Sport Fifth WHL
2017 GMC Sierra 2500 Duramax/Allison
Curt Q20 Fifth wheel, Champion Inverter3500
US Army Retired
Bikersarge is offline   Reply With Quote
Old 10-12-2017, 02:55 PM   #12
Kasual Kamper
Someone suggested spraying your awning with a mild chlorine solution to help retard that.
Old 10-12-2017, 03:04 PM   #13
Bikersarge's Avatar
Yeah, I have and I don't get mold I am just to OCD on my 5er and if something breaks it gets fixed fast, the house different story because it gets added to the list for now, but the 5er....oh no got to get her fixed
US Army Retired
Old 10-12-2017, 03:08 PM   #14
I learned quickly not to stand under it when DW lets it out!
Epat is offline   Reply With Quote
Old 10-12-2017, 04:39 PM   #15
On most awnings in the rolled up position, the top of the roll is above the roof of the RV. This creates a gutter for rain water to run off the roof and it will lay in the "gutter" until you open the awning. The top seam is not 100% waterproof and the water will seep through it. Also the water will seep around the awning bead that slides into the awning rail and sometimes drip or run down the wall of the RV. Some people keep this from happening by extending the awning a foot or two so there is no gutter. I painted the top seam and where the awning connects at the rail with silicone and that stopped the seeping for me.
markb422 is online now   Reply With Quote
Old 10-12-2017, 07:46 PM   #16
On my 2015 8280WS 5th wheel the awning when its rolled up is covered by a clam shell covering that seems to avoid all of the problems that are being highlighted here. The clam shell front end also scrapes all of the leaves etc off the canopy as its rolled up. Good feature.
bruane is offline   Reply With Quote
Old 10-12-2017, 10:13 PM   #17
Filterman's Avatar
Definitely they wick. I've seen people store them with a plastic pop bottle cut to fit over both ends if you are in a heavy winter rainfall area like here in the west coast. I just know I'm th spring to run it out and dump the water and let it dry.
Filterman is offline   Reply With Quote
Old 10-12-2017, 10:15 PM   #18
Someone on this forum recommended cutting 2 liter pop bottles to fit over the ends. I dried the awning last week and put the bottles on. I'll check it this weekend. We had some rain and it's supposed to be dry for a few days.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
awning
