Originally Posted by Aussieguy
bad or flat battery will cause issues to with motors
most MOTORS with high amp draw needs a good constant amp supply (battery)
even if converter is supplying 12.7v may NOT be producing enough amps
you could be running other high amp stuff .. Inverter + TV , water pump
turn off everything 12v
make sure battery is ON .. and in good condition
Two things, one wouldn't being hooked up to 120v bypass all that?
The second thing is that I just went out there disconnected my battery completely and the 120 v and hooked my jump starter up to the camper. All 12v items worked except for the awning. That includes the slide room.
So it doesn't appear that the battery voltage is the issue, unless I'm missing something else.
