Old 05-16-2020, 11:39 AM   #1
DwightB's Avatar
Awning Threads Leak
Hello,
I have a Dometic 21’ awning with the metal travel cover and I have two problems.
First, the awning drips through the seams when it rains. Water drips through the seams onto the chairs, table and stairs.
Second, enough water pools under the travel cover that I can see the awning bulging In the middle. It seems to pool there even when one end of the awning is lowered. I get quite a bath when I do a ‘middle’ dump to release it.
I read that Dometic recommends using paraffin wax to seal the seams. I’ve searched for a wax ‘stick’ to rub onto the seam and couldn’t find any. So, I bought paraffin wax and heated it to liquid, waited until it was fairly cool and painted on the seam. After three applications I’m seeing limited success because if the wax is too warm it just drips through the holes without sealing them shut.
All the while I’m doing this I’m thinking about how much easier it would be to run a bead of silicone over the seam as well as where the top of the cover meets the awning to prevent water from pooling underneath the cover.
Here’s the big question. Does Dometic say to wax it because silicone seal will damage the Dometic awning material or seams?
DwightB is offline   Reply With Quote
Old 05-16-2020, 12:35 PM   #2
Usually Confused Member
emm-dee's Avatar
I wouldn’t use silicone. It’s not very flexible and with repeated movement of the awning it not going to stay in place very long.
Use HH-66 vinyl cement. It says cement but their publications say to use it for waterproofing seams.
Amazon...
https://www.amazon.com/RH-Adhesives-...s%2C158&sr=8-3
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 05-16-2020, 01:03 PM   #3
I would try this for the seam... https://smile.amazon.com/Gear-Aid-Wa...s%2C191&sr=8-4
Now for the puddle in the middle it sounds like you might be over extending the awning. When extending the awning, extend until it stops, this will be over extended. If you look you will see that the awning now has a dam created by the roller that won’t allow water to just flow over the edge. To fix this, retract the awning about a half a turn or so. Hope this is the issue...
2016 Siverback 33IK, Towed 30K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 05-16-2020, 02:04 PM   #4
jeff64's Avatar
Go buy a couple tubes of Coughlan's Seam Sealer. That's what is for
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-18-2020, 06:06 AM   #5
DwightB's Avatar
Thank you
I backed up the awning roller and the awning is more taught. I’ll see how that affects the pooling in the middle.
I ordered the Gear Aid and will try that on the leaking seam,
Thanks for the replies!
Old 05-18-2020, 06:35 AM   #6
Georgia Rally Coordinator
aceinspp's Avatar
I used a product made by Colman that is used to stop leaks on tents worked well. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 15
awning, leak
