Old 04-30-2020, 07:20 PM   #1
Both awnings stopped working
I have a 2017 Vibe 28RL with two awnings. I had them both extended and closed them both at the same time {I know, not to smart} I cannot extend either one. I checked the fuse box and there are no blown fuses. Any idea what might be wrong and how to repair would be very much appreciated.
Thanks,
Dinoburner
Dinoburner is offline   Reply With Quote
Old 05-01-2020, 07:44 AM   #2
SeaDog's Avatar
Check for a resettable breaker in the battery area on the positive cable leading to the awnings. It more then likely will be a small square box with a reset button
Retired Navy
2016 Flagstaff 26 FKWS
Old 05-01-2020, 08:43 AM   #3
Do you have voltage at the switch(es)?
Gotta start with the basics.
Days Camped: '17=30 '18=51 '19=58 '20=83
awning
