Old 04-04-2022, 08:55 AM   #1
Indy500's Avatar
Broken window
I really messed up, or either my camper grew over the winter. Anyway I need to fix this , any help would be greatly appreciated. Model is 8288wsa 2017
ID:	271035   Click image for larger version
ID:	271036   Click image for larger version
Indy500 is offline   Reply With Quote
Old 04-04-2022, 09:13 AM   #2
The pictures are nice, but what are we looking at? Could you describe the problem please?
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 04-04-2022, 09:49 AM   #3
Looks like the top window is broke to me.
scottnlindsay is offline   Reply With Quote
Old 04-04-2022, 10:01 AM   #4
Indy500's Avatar
New picture
New picture
Old 04-04-2022, 10:03 AM   #5
Indy500's Avatar
Can just the top glass be replaced? The frame didn't get damaged, just broke the upper glass.
Old 10-02-2022, 08:37 AM   #6
Irish22's Avatar
What did you find out? Having mine replaced tomorrow at stealer.
Irish22 is offline   Reply With Quote
Old 10-02-2022, 09:38 AM   #7
are you insured
if deductible is around 500 I would put in a claim for window and the cracked fiberglass
check your homeowners insurance it should cover your trailer while parked at house?
check the stickers some more and see if you can find the manufacturer of the window.
or if you can't locate exact window
TAKE OUT the whole window and measure the cut out dimensions and find a window that will fit in the hole
TINT can be added before you install it.
take new window and the old one to a local tint shop
OR
you could try a local glass / window repair company see if they can duplicate glass shape and tint
Fiberglass
use local automotive body shop to repair the fiberglass and color match the gelcoat
DIY ... get a fiberglass repair kit using glass cloth
Poly resin + Bondo will smooth it.
OR using epoxy resin .... Thicken the epoxy instead of using Bondo.
Bondo doesn't stick well to epoxy resins
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 10-02-2022, 01:53 PM   #8
At least on HEHR windows if you take the window frame out there is a label on the frame with the model number. You can use this to reorder the entire window and frame assy. But they are not cheap.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
window
