Old 08-31-2019, 12:26 PM   #1
bvfdchief's Avatar
Cabinet Dovetails Breaking
2020 e-pro not 6 months old and now 2 separate doors have just complete broken at the the dovetail joints. Researching Hoffmann sells about 1000 for $60 and i hope at the rate mine are breaking i dont need the whole bag. Any other better dovetails out there or better solutions? One is a cabinet drawer and other is a slide out but basically made the same. Thanks
ID:	213890   Click image for larger version
ID:	213891   Click image for larger version
2020 E-Pro 19BH with Jeep Wrangler Sahara
bvfdchief is offline   Reply With Quote
Old 08-31-2019, 12:40 PM   #2
Iwannacamp's Avatar
Pocket hole kit and glue. It won’t break again.
2017 Puma 297RLSS
Old 08-31-2019, 12:47 PM   #3
You should still be under warranty. I would insist on door replacement. But if you repair yourself a pocket hole jig as suggested above or perhaps a plate joiner (biscuits) might work.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 08-31-2019, 01:07 PM   #4
LittleBill's Avatar
Same type of thing happened to us. Overhead cabinet doors at both ends fell apart after about the 3rd trip. Dealer replaced them under warranty, but the new ones fell apart after leaving dealer to storage to home (25-30 miles total).
First two pics are the originals and the 2nd two are the replacements. (Sorry about the last one not being orientated correctly.) Not glued just stapled together.
ID:	213895   Click image for larger version
ID:	213896   Click image for larger version
ID:	213899   Click image for larger version
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
LittleBill is offline   Reply With Quote
Old 08-31-2019, 01:58 PM   #5
bvfdchief's Avatar
Thank you for the replies.
Old 08-31-2019, 02:23 PM   #6
Multi-Slacker
If it was me, I'd use pocket screws to get it back together. Those are miter joints and are one of, if not the most, weak joints available to a cabinet maker. Attempting to reglue will most likely fail unless the old glue is removed.
Safe Travels
CurtPutnam is offline   Reply With Quote
