Old 08-17-2019, 06:29 PM   #1
Cardinal Luxury Window Patch
So, I messed up with my new RV. I stopped to take a nap, left the window open and poof! It was gone.
So, I had to figure out the best way to patch the hole for a month while I waited for the new window.
I'm a full timer, and I drive here and there, and can't really have a gaping hole in the side of my RV. My windows are "frameless", not it's not very easy to patch.
So, I started with some plywood and two by fours. And, then I wrapped that in plastic, and added some "Clamps". This is how it turned out:
I hope that this mistake will help others in the future that need to make a "patch" for a window.
Thanks for listening...
Dan
ID:	212686   Click image for larger version
ID:	212687   Click image for larger version
ID:	212688   Click image for larger version
ID:	212689   Click image for larger version
Danryan28 is offline   Reply With Quote
Old 08-26-2019, 04:53 PM   #2
Nicely done. I wouldn't have thought of using hold-down clamps.
If the nice hold-down clamps weren't available, you might have built the outside structure as you did, and used 1x2 battens across the inside, with a pair of carriage bolts on each batten to clamp the structure together.
Larry
Larry-NC is offline   Reply With Quote
Old 08-26-2019, 07:39 PM   #3
I thought of that, but I was alone. This allowed me to inert and remove the patch from inside the RV without having someone hold it up for me.
Old 08-26-2019, 08:07 PM   #4
I was thinking about it, too.
I was thinking about it, too. You would have to:
  • Be inside
  • Put the patch with carriage bolts through the window and place it by holding the carriage bolts
  • While putting tension on a carriage bolt with one hand, insert a batten over the other carriage bolt (or bolts), put on a wing nut, and spin it down tight, using the other hand.
  • Now you have two hands free to finish.
  • Put a batten on the other carriage bolt.
  • Put on a wing nut and tighten it.
Not too bad, as long as you drill the holes in the battens oversized so they easily slide onto the carriage bolts.
Larry
cardinal, window
