Old 09-26-2017, 10:23 AM   #1
Thomsen's Avatar
Compartment locks
I can't get the key into 4 of my compartment locks. Any ideas?
Thomsen is offline   Reply With Quote
Old 09-26-2017, 10:29 AM   #2
WD-40?
I often have to squirt a little in where the key goes after a period of time to get the flap to move out of the way far enough for the key to go in.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 09-26-2017, 12:48 PM   #3
Have the keys been cut? When my DW and I picked up our new trailer a few months ago, the storage compartment keys they handed me didn't work. I quickly discovered that the reason why was because they handed me blanks. They had to quickly hunt around for another set, which isn't hard since 751s are all pretty much the same.
2018 Forest River Rockwood Mini Lite (2104S)
2014 Jeep Grand Cherokee/Summit (5.7L)
nytmare is offline   Reply With Quote
Old 09-26-2017, 01:05 PM   #4
Camper
There is a little "cover" that is inside the cylinder. When you insert the key the cover is supposed to move to the side. This is intended to keep out the elements. I think you just need to lube them. Mine are doing the same thing.
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
Macrosill is offline   Reply With Quote
Old 09-26-2017, 01:12 PM   #5
ben31's Avatar
WD-40 to get them to work, initially. Then, after it begins to work well, squirt in some graphite lock lube (powder). The graphite does an excellent job of keeping everything working, so you don't go through this again.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 09-26-2017, 05:01 PM   #6
Thomsen's Avatar
I did the WD 40 on all of them and still not able to work.
Old 09-26-2017, 05:02 PM   #7
Thomsen's Avatar
I did the WD40 but still not working
Old 09-26-2017, 05:22 PM   #8
dbledan's Avatar
What type of lock is it? Cam lock with a flat key?
I had issues with mine. I bought in winter and they had power washed it for an rv show. It took both lock de-icer and graphite to get them open.
I had bought new cam locks anyway and ended up hitting the little cover with a screw driver and then spraying graphite in to get the key jammed in. I had to turn hard and thought I was going to break the key but it finally broke free. It helps to know which direction to turn it first.
dbledan is offline   Reply With Quote
Old 09-26-2017, 06:35 PM   #9
Unlocked, turn to the right to unlock.
Locked, turn to the left to lock.
Or that is what my Wildcat requires which presumes all are installed as mine are... sorry.
RobertDS is offline   Reply With Quote
Old 09-26-2017, 06:44 PM   #10
Oaklevel's Avatar
Please I am sure that you have but you have tried them both sides of the key the locks are not always the same direction. Also wiggle them a little as you try to insert the key. Just a thought. they can be hateful.
CH 751 keys??
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
lock
