03-25-2018, 08:08 AM
Condensation on Inside of Windows
Hello,
What can I do to prevent or minimize condensation forming on the inside of windows in our TT?
I'm not concerned about when it is stored as we park it in full sun. However, when we are camping -- particularly when we are not running the A/C -- condensation forms on the inside of all windows to the extent that we can't see outside.
Thanks for your help!
Seakayaker
Charleston, SC
2016 Silverado 1500 LTZ
2016 Wildwood 27RKSS
03-25-2018, 08:14 AM
Originally Posted by seakayaker
Hello,
Seakayaker
Go to wally world and buy a 30qt dehumiditier.
03-25-2018, 08:16 AM
Are you using your top vents at all?
03-25-2018, 08:21 AM
I have only one vent that I could open. It's in the bathroom and has a fan.
I have not been opening it except when we shower, etc
Charleston, SC
03-25-2018, 08:22 AM
Does the water collect in the dehumidifier or does it use a hose to drain directly to the outside?
Where to you place the dehumidifier?
If a hose is used, how is it routed to drain?
Sorry for the death by 1000 questions...
Seakayaker
Charleston, SC
03-25-2018, 08:26 AM
Seakayaker
It has a collection tank you pull and dump. It has an auto shutoff if the tank gets full. You can place it in the shower and let it run. Mine is in the living room under the TV. I may try the shower this year.
03-25-2018, 10:01 AM
Are you using the rv propane heater?
03-25-2018, 10:37 AM
Small dehumidifier from Lowe’s.
Velosprout
2014 F150 SCrew 4x4 Max Tow Heavy Duty Payload 3.5 Ecoboost 6.5' bed Ingot Metallic Silver
2015 Rockwood Roo 21SS
03-25-2018, 10:54 AM
you need ventilation, open a window slightly and a vent
2008 rockwood signature ultra lite 8315SS[SIGPIC]
03-25-2018, 12:01 PM
X2 ^^^^ ALL are good and useful suggestions
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-25-2018, 12:03 PM
Run your vent fan more !!!
03-25-2018, 12:23 PM
If you happen to camp off grid the dehumidifier is a wonderful source for water. A simple water purifier tablet and you have some of the cleanest water around as long as you maintain the tank.
03-25-2018, 12:32 PM
100% Agree!!!
Even cracking the ceiling vents 1/4" helps move the air freely.
I recently tested this on a cold weekend at our house. I kept the trailer at 70 and outside temps were in the 30s. I used a small space heater set on low and it only drew 7 amps.
Night 1, the trailer was buttoned up tight with 3 people sleeping in it. Woke up to every window covered in moisture. Wiped them down and dried them during the day.
Night 2, 2 of the 3 vents were popped 1/4". Same 3 people slept, kept the trailer temp at 70. Woke up the following morning and there was very minimal condensation on only 2 of the windows.
The trailer retained heat well but still allowed for enough air movement.
The dehumidifier suggestion isn't bad; however, it is a tool to manage the existing problem. A heater and popped vents eliminates it.
03-25-2018, 01:36 PM
In the shower
Seakayaker
I found a 30 qt unit on Craiglist for $20. I overrode the "bucket in place" switch, removed the shower door, and placed it permanently in the shower. This is in the Cherokee 38P which sits in the same site permanently. The unit drains into the gray tank. The gray tank drain is open all the time when we aren't using the unit, connected by a drain hose to the Blueboy. There have been no issues with freezing.
When we are occupying the camper (usually when the weather is warmer than freezing), we close the gray tank valve and let it accumulate. We can then use the water to flush the hose after draining the black tank.
Larry
03-25-2018, 03:03 PM
Or crack a window or two.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
03-25-2018, 06:19 PM
X2
2014 Shamrock 183
03-25-2018, 07:03 PM
X2
1930 lbs CCC
2014 Jeep Rubicon JK
03-25-2018, 07:08 PM
Definitely should have a dehumidifier. Set it between 45 and 55 percent humidity. Cooking, showering, laundry and breathing all put humidity into the air. Too much can aid in mold and warping of wood and to dry will eat up propane during heating. And crack wood.
03-25-2018, 07:52 PM
If your fan is a Little 4 blade "Noise Maker Type" replace it with a Very Quite upgrade fan! Run it on Low with a window just Cracked! Youroo!!
03-25-2018, 08:23 PM
Windows don’t help if the outdoor humidity is also high. Fans only move the humid air around and don’t remove it. Wet bunk-ends on Hybrids and Popups can be made worse by circulating warm humid air at cooled vinyl canvas. Pop-up gizmos only slow the process, as do double pane windows. The only two real solutions are to prevent humidity (shower-house instead of camper bath, hang wet towels outside, cooking outside) or to use a dehumidifier.
Velosprout
