Old 05-30-2024, 02:13 PM   #1
Dometic 9100 awning spring
Good afternoon,
I'm replacing the fabric on my 9100 power awning. Everything is going pretty smoothly, until it comes time to wind up the spring (9 turns per the Dometic manual.) As I understand it the spring should be fully wound when the awning is extended, and the spring tension assists with retracting the awning. In other words, there should be little/ no tension on the spring when the awning is fully retracted.
The way the manual describes it is exactly the opposite of what I have described above, so it has me confused. Somebody give me a sanity check here- does the spring tension assist with extending the awning or retracting it?
Thanks.
2011 Surveyor SV264LE
2012 F-150 5.0 V8
Jeff Point is offline   Reply With Quote
Old 05-30-2024, 03:16 PM   #2
AudiDudi's Avatar
Are their directional arrow on the end caps that show what direction to wind it?
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is online now   Reply With Quote
Old 05-30-2024, 08:26 PM   #3
No. And even if there were it wouldn’t really answer my question.
2012 F-150 5.0 V8
Old 05-31-2024, 12:17 AM   #4
AudiDudi's Avatar
Yes, the spring tension assists in retracting the awning. I've seen it done backwards and it powered the awning out on a manual awning.
Mike and JoAnne
awning, dometic
